front diff problems!!! - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-10-2011, 05:39 PM
mharring mharring is offline
mharring is starting off with a positive reputation.
im still having tire scrubbing problems, just got it back from the allighnment shop. i was wondering if my 2000 navigator had the vacum solenoids like my 97 expedition? or is this a limited slip axle in front like the rear, i found the original invoice sticker it say i have a 3.73 limited in the rear but is there one in the front, i didnt see any vacum lines or diapram system like in my expedition on the front axle. kinda wondering if it even has one. maybee the 4 wheel is ingaged by the ecm using the transfer case clutches and the diff is always limited slip. im not real shure. this is the first time ive ever troubleshoot a naviagtor but i would have a hard time believing that ford would change the models so much. but i dont know!
any help???? please before i start shootgunning parts at it!!
thanks
Old 06-10-2011, 07:25 PM
I fish's Avatar
I fish I fish is offline
I fish is starting off with a positive reputation.
i think only 97's and 98's have the vacuum actuated front axle. i could be wrong, but that's what i remember. i know for sure that my '98 has vacuum actuated front
Old 06-10-2011, 08:53 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Right. That's because those 2 years had 2WD position on the selector switch. (Can't remember if 1999 also had the 2WD option or not?).
Old 06-11-2011, 09:53 AM
yeah it kinda makes sense now, i guess the only real question i have is "are these front diffs in navigators a limited slip or are they open?"
im really leaning towards bad ball joints and or wheel bearings and possible CV shaft damage, im thinking that the CV shafts are fine, they look real nice and tight. what bothers me is if one of these or all of them are bad how the hell did they get it to alighn properly??? i was under the impression with bad ball joints or wheel bearings u will never get a good alighnment! im gonna do the grab the wheel and move it while in the air to test the bearing. im betting thats my problem or the ball joint it self! ill keep anyone who cares posted!
Old 06-11-2011, 01:25 PM
Quote:
Open.
I like to keep the the left front wheel on the ground while I check the right front wheel and vise versa. That way when you grab the wheel at 3 & 9 o'clock and move it back and forth, the opposite wheel tends to hold steady, making it is easier to identify play in the tie rods/idler arm/pitman arm. Grab the wheel at 12 & 6 o'clock to feel for wheel hub play. And for BJ play, I put a heavy pry bar under the tire and pry it up with my hand held on each ball joint to feel for BJ play.
What are the symptons that show you are having tire scrubbing problems?
Old 06-12-2011, 09:59 AM
Quote:
Originally Posted by pdqford View Post
Open.
im pretty shure the tie rods and idler arm and pittman arm bushing are all shot!!
i cant get any wheel bearing play so im good there but i can take the tire at 3 and 9 and move the whole tire about a 1/2 on both ways the pitman arm and the drag link and idler all flex with it but the tie rod bushings are blwon out they look in reall bad shape all the others are not far behind, obviously ill get new tie rods but do they make front end bushing kit for navigators! i dont know but ill be taking back to the allighnment shop and making them fix it, so ill have a front end inspection done there, its funny im a mechanic in a huge mine and dont have time to fix my own stuff!!!! i was really worried about my t-case i thought the 4 wheel drive was engaging but its not!!
Old 06-12-2011, 10:43 AM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
I'm pretty sure the front axle is an open rear, not a limited slip at least from the factory!
Rear and front diff lockers? TractorM3 2015+ F150 1 12-13-2015 05:29 PM
Differential swap question Mr_KnowNothing 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 08-25-2014 09:59 AM
Rebuilding Limited Slip skyfox10 1987 - 1996 F150 & Larger F-Series Trucks 17 03-16-2010 10:39 PM
how does limited slip work? Mr. Finch Clutch, Transmission, Differential, Axle & Transfer Case 3 12-28-2008 09:34 PM
limited slip {posi} charlierogers 1999 to 2016 Super Duty 18 09-30-2008 09:31 PM
Tags
2003, 97, bearing, check, connection, diff, differential, expedition, f150, ford, front, play, problems, ranger, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
