96 4.9L driveability problems.. gremlins!! - Ford Truck Enthusiasts Forums
Old 06-10-2011, 05:08 PM
Danodemano Danodemano is offline
Danodemano is starting off with a positive reputation.
Hello fellow Ford drivers! This is my first post, I have been lurking around for awhile and have found this site quite helpful in the past, but now I need some interactive help from those with experience!
I have a 1996 F150 4x4, automatic with the 4.9L. The truck has 88,000 original miles, and NO rust. I bought the truck from the original owner who told me it needed a Crankshaft position sensor. I brought it home to find a reman distributor installed and the timing WAY off. I timed it ( more on that in a second) and it ran smoothly but with barely any power.
I replaced the Crankshaft Position Sensor, no change. I hooked up my timing light and advanced the timing to 14 degrees ( more again later ) and it ran with noticeable more power , especially under 2500 RPM. But it still was a dog above that RPM
Thinking about this , knowing its a timing/iginition issue, I replaced the Spark plugs, gapped at .45 per factory specs , replaced the distributor , wires and cap and rotor with the best parts. It still ran the same. The spark plugs had a light brownish color indicating that the engine is running lean.Now to the timing Snafu:
When I time the engine, the harmonic balancer has a notch in it assuming its for TDC. The ring mounted behind if for the Crankshaft Position Sensor also has two pickup points and one of them is what Ive been using all along as a timing reference. The harmonic balancer itself currently has no marks even 180 degrees close to the nub I am using on the CPS ring for timing. The truck runs smooth, starts everytime well, gets horrible gas mileage ( like 10-12 mpg) and has good power under say 3000 RPM but still doesnt seem to have the power it should.
No check engine lights, the only thing that is changed from the factory is the Air tube going down to between the two converters is removed as is rusted off. I welded the hole shut on the exhaust pipe, thats it.
Anyone have any pointers or tips??
Thanks in Advance!!!
Old 06-15-2011, 10:17 AM
Ranger GT2's Avatar
Ranger GT2 Ranger GT2 is offline
Ranger GT2 is starting off with a positive reputation.
I'm not that familiar with the fuel injected ones, but on the carb models the dampener has a rubber piece in the middle of it. If the outer part of the dampener should happen to slip your timing marks on the dampener would not be correct. You may check to see if there is a repair manual that can give you more detail about the timing.
I've never had a fuel injected six but on the carb models if it is stock your not going to have much higher rpm that 3000 rpm.
Old 06-15-2011, 12:58 PM
RC Dan RC Dan is offline
RC Dan is starting off with a positive reputation.
Sounds like you may be timing it wrong. Your using the timing indicator on the passenger side, right? You don't use the ones stamped into the timing cover on the driver side. I have no idea why those are there.
And that crankshaft sensor is nothing more than something for emissions control. It plays no part in timing or fuel.
Old 06-16-2011, 06:35 AM
There are timing marks on the passenger side? Weird, I never noticed. No I am timing from the marks on the drivers side. I will look for the other marks today. Thanks! for the help!!
Old 08-24-2013, 06:49 PM
Zapp911's Avatar
Zapp911 Zapp911 is offline
Zapp911 is starting off with a positive reputation.
Quote:
Oh Really?
Vacuum advance 101 winginit 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 70 11-10-2016 12:15 AM
4.9 misfire Prof2113 1987 - 1996 F150 & Larger F-Series Trucks 18 07-29-2016 11:34 AM
Speedmaster Harmonic Balancer flowney FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 04-07-2016 11:05 AM
99 F-150 4.2 harmonic balancer timing Frank1721 1997 - 2003 F150 3 09-25-2014 10:05 PM
5.0 Harmonic Balancer Marks Hypoid Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 06-28-2014 01:48 PM
Tags
1996, 2005, 49l, 96, crank, dist, drivability, driveability, egr, f150, ford, posiition, problems, sensor, tsb, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
