map sensor location/help
Old 06-10-2011, 10:30 AM
xc4jokestomper's Avatar
xc4jokestomper
xc4jokestomper is offline
wheres the map sensor at on a 95 F150 302? I was on fullsizebronco today and yesterday and they have an excellent writeup on redoing the vacuum lines. one part of it however was running a new line from your map sensor to the vacuum tree. they had a very nice picture but it looked like their engine bay and mine was different. does anyone have a picture of what their map sensor looks like? i think where mine is it had a heat shield type material covering it and when i pulled it off it had a plastic box covering and a line coming up out of the top of it. should that be it?
Old 06-10-2011, 11:01 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,156 Likes on 914 Posts
Your truck is MAF, not Speed Density therefore you do not have a MAP/BAP sensor. After 1994 Ford figured out the MAP sensor was not that useful when using MAF so they eliminated it.
Old 06-10-2011, 11:21 AM
xc4jokestomper
Oh. Maybe thats why i couldnt find it lol.
Old 06-10-2011, 11:32 AM
xc4jokestomper
ok well my next question is what is this and is it really necessary?
the bronco guys have theirs set up alot differently and when i redid mine this is the way mine was setup so i just redid it the same way.
Old 06-10-2011, 12:04 PM
rla2005's Avatar
rla2005
rla2005 is offline
That is a quick disconnect for the vacuum lines. No it is not necessary, you can bypass it by running the vacuum lines from the vacuum tree on the manifold to each device.
rickdavis81
05-12-2016 04:34 PM
Jmanb13
09-19-2015 07:48 PM
WILLYG247
13
12-22-2010 04:09 PM
kirbykoon
10-14-2010 05:23 PM
444dieselrod
02-20-2005 07:15 PM
Quick Reply: map sensor location/help
