Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-10-2011, 10:30 AM
xc4jokestomper xc4jokestomper is offline
1995 Ford F-150
xc4jokestomper is starting off with a positive reputation.
map sensor location/help
wheres the map sensor at on a 95 F150 302? I was on fullsizebronco today and yesterday and they have an excellent writeup on redoing the vacuum lines. one part of it however was running a new line from your map sensor to the vacuum tree. they had a very nice picture but it looked like their engine bay and mine was different. does anyone have a picture of what their map sensor looks like? i think where mine is it had a heat shield type material covering it and when i pulled it off it had a plastic box covering and a line coming up out of the top of it. should that be it?
__________________
1995 F150 Supercab Flareside: 302ci, 4r70w, 4x4, 3.55ls, 3rd owner, 100k miles
Current mods: 31x10.5, rear roll pan, Smoked Headlights, FM 40 si/do, Superlift leveling kit,
Future mods: shift kit, true duals, 8k hid's, DIY tonneau cover, Electric fan
  #2 (permalink)
Old 06-10-2011, 11:01 AM
rla2005's Avatar
rla2005 rla2005 is offline
2004 Ford Excursion
rla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to all
Your truck is MAF, not Speed Density therefore you do not have a MAP/BAP sensor. After 1994 Ford figured out the MAP sensor was not that useful when using MAF so they eliminated it.
  #3 (permalink)
Old 06-10-2011, 11:21 AM
1995 Ford F-150
Oh. Maybe thats why i couldnt find it lol.
  #4 (permalink)
Old 06-10-2011, 11:32 AM
1995 Ford F-150
ok well my next question is what is this and is it really necessary?
Click the image to open in full size.
the bronco guys have theirs set up alot differently and when i redid mine this is the way mine was setup so i just redid it the same way.
__________________
  #5 (permalink)
Old 06-10-2011, 12:04 PM
rla2005's Avatar
2004 Ford Excursion
That is a quick disconnect for the vacuum lines. No it is not necessary, you can bypass it by running the vacuum lines from the vacuum tree on the manifold to each device.
Tags
1995, 1996, 64, diesel, f150, f250, ford, locaction, location, maf, map, pickup, sensor, truck, wheres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
