Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 06-10-2011, 10:18 AM
villiano villiano is offline
Garage is empty, add now
villiano is starting off with a positive reputation.
Intro and help from Durham
Hi all, This is my first posting. I have a 1977 F100, inline 6. She was running fine until recently. But now she runs real rough, and there is a lot of smoke coming out the tail pipe. It's darker in color, so I don't think it's water vapor. Anyone have any ideas what could be the problem? Do I have a blown head gasket? How can I test? Thanks much for any advice.
  #2 (permalink)
Old 06-11-2011, 10:04 AM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
fuzzy1626 is starting off with a positive reputation.
Sounds like to much fuel. Check air intake for restriction and filter condition, check for correct choke operation, carb float level.
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs,E4OD,4.10 gears, K&N air filter,Hayden 679 trans. cooler,PSD oil filter,coolant filter and vac. operated heater shut off valve, manual glowplugs,Autometer water temp.,trans. temp., and pyro in three guage pillar pod, Autometer mechanical oil pressure under dash with twin vac/boost guages,TruxPort tonneau cover,straight piped,189,000 miles and counting. 88 Ranger 2.0, 5 speed,147,000 mi.,bought new.NC Chapter Member,IUE Retired, NRA Life Member,USMC.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
