Turbo Lag.... - Ford Truck Enthusiasts Forums
Turbo Lag....
Old 06-10-2011, 06:04 AM
cmdevildog16's Avatar
cmdevildog16 cmdevildog16 is offline
cmdevildog16 is starting off with a positive reputation.
Turbo Lag....
Is there anyway to reduce the amount of turbo lag on take off? when taking off from a light even if i punch it, it takes about 5 to 7 seconds to react...just curious.
Old 06-10-2011, 06:19 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Probably not on a stock truck. A couple of options are getting your FICM tuned by PHP, which is a LOT less invasive than PCM tuning, or getting a tuner. Try two footed driving--hold the brake and give it a SMALL amount of fuel before leaving a stop and roll into the throttle rather than punching it (which makes lag worse).
Old 06-10-2011, 06:25 AM
ok, thats what i figured, but now i have another question going off of what you said about FICM tuning....is it better than say going the sct route for your truck and do you get the same kind of results?
Old 06-10-2011, 06:32 AM
Quote:
FICM tuning is a different animal than PCM tuning entirely. You don't get the big HP gains that you do with PCM tuning. It's more of an adjustment to driveability than performance. Typical gains are 1-3 MPG and better throttle response although not every truck responds the same.
Old 06-10-2011, 06:34 AM
ok hmmm that is definatley somthing to ponder as i was going to get the sct sf3 soon but now im not sure what to do...lol...thank you for the information
Old 06-10-2011, 07:03 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
The stock program will lag because of air to fuel with no smoke, a custom program will get rid of the lag and give a better throttle responce. Nothing hot, just a mild street tune or try Partsmans suggestion.
Old 06-10-2011, 09:56 AM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
Alot of my turbo lag went away as soon as I got rid of the y-pipe feeding the EGR cooler....almost instantaneous throttle response now.....and ofcourse an SCT tuner
Old 06-10-2011, 10:49 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
5-7 seconds lag isn't normal. Tell me this, if you go WOT from a stop, does it barely creep along until it gets to about 2300rpm, then take off like a scalded cat? If that's the case, it sounds like your turbo vanes are stuck in the open position and it needs to be taken apart and cleaned at least.
Huge turbo lag and lots of black smoke on take off awsmev 6.4L Power Stroke Diesel 5 03-07-2017 10:48 AM
2004 ford 350 6.0 diesel turbo lag and black smoke lilshoe4me 6.0L Power Stroke Diesel 3 07-02-2014 07:30 PM
F250 Turbo Lag RD688 6.0L Power Stroke Diesel 10 09-03-2011 03:50 PM
What would cause bad turbo lag? guthrie&co 6.0L Power Stroke Diesel 20 10-17-2010 02:37 AM
Turbo lag on a 97 PS beachbummin220 1994.5 - 1997 7.3L Power Stroke Diesel 7 11-06-2005 07:25 PM
Tags
2003, 2006, 60, 60l, 64, 73, acceleration, diesel, f360, ficm, ford, lag, lagging, reduce, rid, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
