I need help with my 94 explorer stereo wiring - Ford Truck Enthusiasts Forums
Old 03-26-2003, 05:09 AM
loadtoad666 loadtoad666 is offline
loadtoad666 is starting off with a positive reputation.
Angry I need help with my 94 explorer stereo wiring
OK, does anyone know what wire is what? I can't seem to figure it out. the colors are, light green/white, black/green, yellow/black, light blue/red, blue and black. If anyone can help me or give me a link to where I can find this at I would greatly appreceate it.
Loadtoad
Old 03-26-2003, 09:01 AM
jbelew jbelew is offline
jbelew is starting off with a positive reputation.
I don't remember the colors but I do remember that my wife's '94 had a built in amp. I bought a stereo from Crutchfield and they said that I would either have to bypass the factory amp (which was located in one of the rear quarter panels) or purchase a device to put inline that would dampen it before it went through the amp. That little jewel was like $50 at Circuit City.
Maybe this didn't help any, but I thought I would throw it out there.
Old 03-26-2003, 07:53 PM
PrPlayboy PrPlayboy is offline
PrPlayboy is starting off with a positive reputation.
It looks like there are only two speakers with that set of wires. The best thing to do is pull the speakers out and see what colors they are. See if those colors match the colors at the harness. Sometimes they don't. If you have a multi meter that will tell you what is what. Dont quote me on this but from my expiereance I would Assume:
The Black is ground
Blue is for power <a href="http://www.motorhaven.com/">antenna</a> or amp lead
Red/blue is for ignition on
Yellow/black is for constant power (ie clock memory)
Green/white is for left or right speaker
Black/green is for left or right speaker
Now there should be an amp that is taking high level inputs because you would need two wires per speaker. An amp only has one wire coming into it from the radio for power and that would be the blue lead in most cases. Chances are the green/white and black/green wires are giving the amp the signal and the amp is then feeding thw two or four speakers. If you have four speakers then the amp is using one wire for the front and one for the rear and its not running in stereo.
This is just me putting a mental picture in my head. I hope this helps in some ways if not you can go to almost any auto parts store, matbe even Walmart and buy a harness that will fit into your car but again if it has an amp you may run into trouble.
2007/2008 mirror swap wire color help kingeightclub 1999 to 2016 Super Duty 5 11-30-2016 07:05 PM
06 to 08 Seat Wiring Problem Project-55 2004 - 2008 F150 0 11-17-2013 11:14 AM
need help on wiring a cd player in a 89 bronco ll nufrdm Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 10-31-2005 02:00 PM
Customer Access Wires . . mikewrt 1999 to 2016 Super Duty 1 10-19-2003 11:49 AM
steering column wires and backup lights ROKRAWL 1966 - 1977 Early Broncos 1 06-16-2003 11:38 PM
Tags
94, 96, amp, amplifire, black, bypass, explorer, factory, ford, radio, stereo, wire, wires, wiring, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
