Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 06-09-2011, 10:55 PM
sknybird sknybird is offline
Garage is empty, add now
sknybird is starting off with a positive reputation.
1993 ford ranger engine swap
just curious if anyone knows if a 1993 ford ranger 3.0 engine is interchangeable with a 1999 ford ranger 3.0. thank you
  #2 (permalink)
Old 06-12-2011, 12:54 PM
Roger1960 Roger1960 is offline
Roger1960 is starting off with a positive reputation.
I would guess there would be some changes. For one the 99 will be an OBD II system, and this would mean that the sensors and wire loom and computer might be different.
One way to deal with this would be to swap every thing over like the OBD II plug under the dash and perhaps even the instrument cluster.
You also might be able to put all of your sensors on to the new engine. The pitfall to the latter plan is that you might run afoul of the emissions laws. In CA, newer engines in older vehicles must have all the mandated emissions systems of the newer car, plus the smog referee has to approve of everything.
If the swap is done on an exact engine then no problems passing a smog check.
Also lets say you sell your truck before the next smog check and the buyer flunks the emissions test due to "tampering" The seller is then liable to restore the car to a legal position, That means you are on the hook for any issues discovered after the sale.
  #3 (permalink)
Old 06-16-2011, 11:10 PM
bazzman1953's Avatar
bazzman1953 bazzman1953 is offline
bazzman1953 is starting off with a positive reputation.
I have a '94 and it is still an obd II. A '99 with obdII?
__________________
'94 Mazda B4000 SE 4.0L 4x4 M5OD X-cab
"YOU DON'T NEED A BLOODY CHERRYPICKER TO GET THINGS OUT OF THE BED"
'91 F-150 4x4 SLT Lariot longbed capped and bedlined
  #4 (permalink)
Old 06-17-2011, 06:56 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
The industry phased in OBD-II in or around 1996. Vehicles prior had manufacturer specific diagnostic connectors and readouts. The code-reading tools were all different, how to access the codes was different, and what the codes meant were all over the place.
OBD-II standardized the connector, the codes and their meanings.
From wiki:
# ~1994: Motivated by a desire for a state-wide emissions testing program, the CARB issues the OBD-II specification and mandates that it be adopted for all cars sold in California starting in model year 1996 (see CCR Title 13 Section 1968.1 and 40 CFR Part 86 Section 86.094). The DTCs and connector suggested by the SAE are incorporated into this specification.
# 1996: The OBD-II specification is made mandatory for all cars sold in the United States.
FWIW.
tom
Oh, yeah, the block and heads will be the same. You can even use a Taurus/Sable or Tempo/Topaz Vulcan. Just need to fiddle with the intake and accessories. The later models added the CKP and CPS, crankshaft and cam position sensors. Which means the timing chain, or front cover, may need to be changed, and the distributor replaced with the CPS stuff.
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #5 (permalink)
Old 06-17-2011, 09:33 AM
watts1989 watts1989 is offline
watts1989 is starting off with a positive reputation.
WILL A 1989 5SPD MANUAL TRANS WORK ON A 1992 3.0L BOTH ARE RANGERS.
  #6 (permalink)
Old 06-17-2011, 06:03 PM
BlueOvalDude's Avatar
BlueOvalDude BlueOvalDude is offline
BlueOvalDude is starting off with a positive reputation.
Quote:
Watts,
I don't think it will work. I looked up the transmissions on fordspartgiant.com and a few other Ford parts websites and it seems as though Ford only offered a 5-speed Mazda M5OD-R1 unit for both new V-6 engines introduced in 1990. The 1989 Ranger V6 only offered a Mitsubishi FM unit. Hope this helps
Tags
1993, 1999, 30, 30l, 50, 93, engin, engine, ford, interchange, kit, motor, ranger, swap, swaps, to
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
