4spd bellhousing - Ford Truck Enthusiasts Forums
4spd bellhousing
Old 06-09-2011, 11:06 PM
salf100's Avatar
salf100 salf100 is offline
salf100 is new and has a neutral reputation at this point.
4spd bellhousing
Looking for the part number if any and anyone selling a bellhousing that came on the 51-53 trucks that had a flathead motor and four speed trans. Thanks
Old 06-10-2011, 08:34 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
I cant see through the grease an grime on mine ..but Ican check the spare motor over the weekend and let you know..
Old 06-10-2011, 08:39 AM
Granny1153's Avatar
Granny1153 Granny1153 is offline
Granny1153 is starting off with a positive reputation.
1953 had a different bellhousing, one of a kind and only 1 year except canada. Similar to the 6 cyl and y- block motors except the mounting bolts were narrower. The part # that i came up with in my search is taac-7505-A. I am looking for a 53 ford flat head bell housing.
Old 06-10-2011, 09:27 AM
salf100's Avatar
Ok, what's the model name of the both transmissions, 51-52 & 53. I'm tring to get the info for a buddy that's doing a custom set up with an S-10 T-5
Old 06-10-2011, 01:37 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
I'm pretty sure Ilya has one (aka 51panelman).
Dan
Old 06-10-2011, 05:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Quote:
I would guess what he's after is a "hogshead", you should ask him to be sure. The bigger truck trannies had a separate piece behind the bellhousing that the trans attached to. Those are popular to adapt an S-10 trans. See below:
T5 Transmisison Swap
http://www.ford-trucks.com/forums/48...sing-help.html
Tags
taac7505a
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
