stupid DEF nozzle adapter!!!!!!
Old 06-13-2011, 10:36 AM
cummins cowboy's Avatar
cummins cowboy
cummins cowboy is offline
yeah I just have the basic info center on my XLT, which I think is the same as the XL model as well, I think the full out info center was another $2500 if I wanted that.
Old 06-17-2011, 06:55 PM
azfarrier's Avatar
azfarrier
azfarrier is offline
Originally Posted by kper05
My local AutoZone doesn't even carry DEF nor do they know what it is.
My local Napa guy still thinks DEF is just urine and said he'd just pee in the tank. No Joke!!!
Old 06-17-2011, 07:13 PM
lakedweller's Avatar
lakedweller
lakedweller is offline
Seems to me Ford should have supplied the adapter......
I have heard of others filling up their diesels with gas and one that did the reverse. I try to READ the pump before filling mine up, screw the pump handle cover colors ....
Old 06-26-2011, 01:59 PM
porthole's Avatar
porthole
porthole is offline
Originally Posted by cummins cowboy
I just found a use for that stupid little cubbie hole on my truck that is right below my 4x4 selector and to left of my fold down cup holder. I always thought it was strange that the cubbie didn't even have a lip to it to acutally hold anything.
anyways my DEF magnetic misfill thingy wedges itself nicely in there.
I use that cubby to keep my old garage door opener, since the factory link hardly ever works.
Old 06-26-2011, 05:24 PM
Marauder92V's Avatar
Marauder92V
Marauder92V is offline
Funny you should mention the Homelink door opener. I have 3 garage bays and 3 different openers (don't ask, I'm a cheapskate by nature). I have noticed that the 2 more current ones with the rolling codes were more difficult to open over the older fixed code. What I have found that works for the more modern ones is to hold the button for up to 5 seconds. I think for some reason it takes that long for the rolling code to be transmitted.
The fixed code unit can be simply pushed more quickly.
Old 06-26-2011, 09:49 PM
kper05's Avatar
kper05
kper05 is offline
Nothing strange there.
I always have had and do have a separate door remote for each door.
Old 05-18-2012, 10:15 AM
rob17's Avatar
rob17
rob17 is offline
Originally Posted by PowerStrokeHD
Ah yes...
They probably sold you something like this... OPW 21Gu Mis-Filling Prevention Device (MFPD)
According to the web site: The MFPD is permanently installed in DEF tank fill pipe.
Has anyone actually installed one and how does it effect the use of the jug nozzles?
Rob
Old 05-21-2012, 11:11 PM
rw4ducks's Avatar
rw4ducks
rw4ducks is offline
Magnet
Anyone tried just sticking a magnet on the outside of the nozzle? Small super strong magnets are like $.50
Old 05-22-2012, 10:51 AM
cummins cowboy
its not that bad using the thing, it just sucked paying $15 bucks for it out of the gates. considering I will be using this thing for a long time and maybe even with future trucks its not that big of deal. although it does take some manipulation to get the thing on there right to get the pump to turn on. nowadays bulk DEF is the only way I buy it at the pump. I am not paying $12/gal out of the jugs.
Old 05-22-2012, 11:08 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is online now
Received 7,053 Likes on 2,212 Posts
Around here you can get the 2 1/2 gallon jug for $11. That is $4.40 a gallon and not too bad.
Old 05-22-2012, 12:04 PM
the_webers_inc's Avatar
the_webers_inc
the_webers_inc is offline
A mostly quiet Supporter
DEF is $2.69/gal. at the pump around here. Never realized how lucky we are - pay at the pump and no MFPD!
Old 05-22-2012, 04:07 PM
los341's Avatar
los341
los341 is offline
how hard is it to measure the DEF tank just like the fuel tank gauge does??
The most common method for measuring fluid level is with a float-type gauge. Since the DEF freezes below about 15 degrees, mechanical moving parts are avoided because of the wear-and-tear that freezing causes. Instead, a few discrete on/off sensors are used at pre-selected levels.
Carl
  #28
Old 05-22-2012, 04:17 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
I went to flying J / pilot website and got their rvpluscard which allows pay at the pump and up to 12 cents cheaper diesel and the def was like $2.70 IIRC
they are not the easiest to find and not always the cheapest... but filling up the def while there makes up for it ! as I have been GOING thry that def - 3 fillups in 7000 miles !!!
  #29
Old 05-22-2012, 06:13 PM
dmags's Avatar
dmags
dmags is offline
adapter
So It sounds like this would be something you would like to have in the glove box.
If you are on a trip and need DEF and decide to purchase it at a filling station you would need this correct?
  #30
Old 05-25-2012, 09:57 AM
DK Farms's Avatar
DK Farms
DK Farms is offline
I can get bulk DEF at Love's Truck Stop. They keep the magnet thingy behind the counter and will let you borrow it if you know what to ask for. However, there is no pay-at-pump option, probably because they don't want you driving off with the magnet.
Quick Reply: stupid DEF nozzle adapter!!!!!!
