Starting problem - Ford Truck Enthusiasts Forums
Starting problem
Old 06-09-2011, 08:15 PM
seawulff seawulff is offline
seawulff is starting off with a positive reputation.
Starting problem
Periodically my 56 F100 won't turn over. If I turn the key a couple of times sometimes it starts. When it doesn't start I hear a clunk under the glove box area possilbe the solenoid. It doesn't click. My battery is new, the ignition switch is new and the wiring is new. When it turns over it does so rapidly and starts easily. Does this sound like a solenoid problem, what's the best way to test it since it's intermittent? Thanks in advance.
Old 06-09-2011, 08:26 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
It would be cheap and easy to buy a solenoid @ Napa and change it out.If you suspect the solenoid on the starter,pull the starter and take it to an electrical shop,they'll bench test it for you @ NC,usually.
Old 06-09-2011, 09:29 PM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
check your ground straps and grounding points on the cab to frame and solenoid ground ,,most of my problems with any old car or motorcycle has been bad wireing (you have taken care of that) or bad ground..but yes a solenoid is cheep to replace ..if your wrong ..you have a spare..
Old 06-09-2011, 10:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
If it isn't a bad connection, I think it's more likely the starter. Badly worn brushes will do that sometimes.
Old 06-10-2011, 12:47 PM
How do you test the starter?
Old 06-10-2011, 03:47 PM
53pickemuptruck's Avatar
53pickemuptruck 53pickemuptruck is offline
53pickemuptruck is gaining momentum as a positive member of FTE.53pickemuptruck is gaining momentum as a positive member of FTE.
Sounds like a grounding problem,loose connection somewhere.
Old 06-10-2011, 07:23 PM
kenjh's Avatar
testing the starter you need a volt meter on the battery .try cranking it over ..the battery should not drop below 10.5 volts while cranking ..if it drops to 9 volts or lower ..the starter is dying also after trying to start it ..grab the starter cable if it is warm or hot ,,it is either loose or undersize,,let us know what you find ..
Tags
f100, ford, starting, stay, trouble, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
