Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
Fuel line retro fit
Old 06-09-2011, 06:49 PM
1sscav 1sscav is offline
1sscav is starting off with a positive reputation.
Fuel line retro fit
I have a 93 Bronco that has a frame mounted fuel filter that takes specialty tools to remove. The tool is the same type that is used to remove the fuel lines from the gas tank. My old 89 Bronco used disconnects that utilized a plastic clip that could be removed with a screwdriver.
My question is, can I retro fit my 93 Bronco with 89 Bronco fuel lines (and the filter worm style clamp) with minimum difficulty?
Thanks for any and all help.
Brian
Old 06-09-2011, 07:47 PM
Southern Bronco's Avatar
Southern Bronco Southern Bronco is offline
Southern Bronco is gaining momentum as a positive member of FTE.Southern Bronco is gaining momentum as a positive member of FTE.
SouthernBronco
Anything is possible,but I don't think its worth the effort when you can get the fuel line release tool fairly cheap.Besides its a real pain to splice the lines.
Old 06-09-2011, 09:51 PM
I have the correct tools to remove the filters, but they're not releasing the fittings. And I want to replace the entire fuel line from tank to engine. The factory set up is just too much of a hassle to work with in a reasonable amount of time.
Old 06-10-2011, 12:14 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
In a word, NO. There is too mug pressure in the system in a 93 from the tank all the way to the rail. The 89 didn't have the full fuel pressure until fuel moved through the frame-mounted high pressure fuel pump. The 93 has the full 40 psi coming from the pump in the tank. The fittings that are on the 93 are necessary with that kind of pressure. If you try to use anything else you will burst connection point and have raw fuel pumping all over the road and undercarriage. There is a good reason it's so difficult to open the fittings. Spray them with penetrating oil an hour before you try removing them.
__________________
The only stupid question is the one you DON'T ask!
Big Bronco FAQ's
Old 06-10-2011, 07:38 PM
SouthernBronco
The easiest way I found to remove the fuel lines when they stuck is spray alittle brake cleaner in to flush out any sand/dirt around the line
Old 05-08-2015, 09:51 AM
Brian Ski 44 Brian Ski 44 is offline
Brian Ski 44 is starting off with a positive reputation.
Quote:
Originally Posted by greystreak92 View Post
In a word, NO. There is too much pressure in the system in a 93 from the tank all the way to the rail. The 89 didn't have the full fuel pressure until fuel moved through the frame-mounted high pressure fuel pump.
I agree... The older system used a few psi 3 or 4. The new system uses at least 10 times that. The rubber hoses are just not rated that high. I think it would work for a while. How long till a line blows off???
BTW you should have the plastic clips. You pry them out with a screwdriver, slide off the line, reinsert the clips(or new ones), then they just snap on. Unless you have the metal ones. Those seem to give me more trouble. More common on the chevys.
Similar Threads
Transmission swap?? Chaulky8 Ford Inline Six, 200, 250, 4.9L / 300 11 01-11-2015 11:39 AM
Retro-Fit Cam Question Bamadawg63 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 05-04-2014 11:40 AM
93 to an 89 tranny swap 93'Bronco 1978 - 1996 Big Bronco 35 01-27-2014 07:02 AM
key pad entry re-fit flysf150 1978 - 1996 Big Bronco 1 01-10-2014 07:47 PM
CV rear drive shaft? Old93junk Bronco II 5 10-30-2013 01:01 AM
Tags
1996, 89broncofuellines, 93, bronco, fuel, line, lines, removal, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
