51 f-2 engine rebuild question? - Ford Truck Enthusiasts Forums
Old 06-09-2011, 01:30 PM
BigJon626 BigJon626 is offline
BigJon626 is starting off with a positive reputation.
Talking 51 f-2 engine rebuild question?
i am going to have my 239 v8 rebuilt. should i have it bored to .30 or leave it ? and also is there anything else i should do? i am going to order a rebuild kit soon and need some specs. thanks!
Old 06-09-2011, 02:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Is it Standard now? Have you got it open? There's no reason to go more than is needed, but you do gain compression ratio (and a few cubic inches) as you increase the bore. Most flatty's can be taken out to almost 1/8", unheard of with modern engines, but ultrasonic testing is needed before going that far.
Generally the standard O/S's are .010, .020, .030, .040, .060, with aftermarket sizes above that. One thing that is sort of new is using "metric pistons" and rings. I don't know a lot about them, but essentially they are not quite a standard O/S, but have thin rings that greatly reduce drag and wear yet seal better. The metric pistons are also lighter. As always, you want the pistons in hand before the boring bar hits the cylinder walls.
Here's a good discussion on pistons and rings: http://flatheadv8.org/phpBB/viewtopi...t=2085&p=12962
Old 06-09-2011, 02:25 PM
52 5 star's Avatar
52 5 star 52 5 star is offline
52 5 star is starting off with a positive reputation.
Have the block setup for full flow oil filter system while it is apart
Old 06-11-2011, 08:53 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
I would not modify the block for the "full flow" oil filter setup. Modern spin on oil filters still have a bypass valve built into them. The filtering media in the filters cannot handle the volume of oil put out by an oil pump. Why plug, drill, add external lines, etc, to add an upgrade that really isn't an upgrade?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
