How to tell the difference betweeb stock altenator and 3G?
Old 06-09-2011, 11:54 AM
JeffNJF150's Avatar
JeffNJF150
JeffNJF150 is offline
My altenator died on my 93 f150 5.0, so I was going to do the 3G upgrade. I think the truck may already have a 3G, as it looks similar to photos I have seen online. How can I tell the difference? Also will a pulley from a stock altenator fit on a 3G altenator?
Thanks!
Jeff
Old 06-09-2011, 01:01 PM
86F150302's Avatar
86F150302
86F150302 is offline
2G has external fan.
3G
3G alternators
(1994-95) Ford Mustang 5.0L
(1994-00) Ford Mustang 3.8L
(1994-97) Ford Thunderbird, Mercury Cougar 3.8L
(1990-95) Ford Taurus, Mercury Sable 3.8L
(1993-99) Ford Taurus, Mercury Sable 3.0L
(1995-98) Ford Windstar 3.8L & 3.0L
(1991-94) Lincoln Continental 3.8L
(1992-97) Ford F Series Pickup
(1992-96) Ford E Series Van
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
The old 2G pulley will work on a 3G.
Old 06-09-2011, 01:04 PM
rla2005's Avatar
rla2005
Can't get any closer than that on timing......
Old 06-09-2011, 01:10 PM
86F150302's Avatar
86F150302
LMAO! Great minds think alike
Old 06-09-2011, 04:47 PM
JeffNJF150's Avatar
JeffNJF150
Thanks guys,looks like i have a 3g, a bad one though!
Old 06-09-2011, 04:52 PM
nstueve's Avatar
nstueve
nstueve is offline
did you have it bench tested? I'm not going to lie you can rebuild your alternator with quality parts for less than 1/3 the cost of a cheap chineese/mexico rebuild...
Old 06-09-2011, 04:56 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The only thing that really wears out is the VR assembly the bearings are pretty long lasting
Old 06-09-2011, 04:59 PM
ford390gashog
Also there is two types of 3g alternators a large case and a small case. The small case has 4 holes in the cros ribs and the large case only has two holes like the above picture.
small case on the left large on the right http://www.supermotors.net/getfile/6...e/115_1530.jpg
Old 06-09-2011, 05:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
There are 2 hole (large 148mm 130A) and 4 hole (small 135mm 95A)
There are 3 mounting styles. (side mount, 7" & 8 1/4" spread)
Quality bearings, rectifiers and regulators can also be found on Ryan's site. RJM Injection Tech — Alternator Accessories
Old 06-09-2011, 08:55 PM
JeffNJF150's Avatar
JeffNJF150
Awsome guys thanks! Looks like u have a small case 95A 3G, I was actually thinking of just buying a new 160A 3G from RJM, i guess it should just hook right up
Old 06-09-2011, 09:20 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
What the heck?! my Bronco is a 92 and i think it came with a 3G (i previously thought it had a 2G, but mine doesn't have an external fan and resembles a 3G a lot, it also came factory installed), that would be great news! . Does that means i should upgrade the cable?.
Old 06-10-2011, 04:21 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Factory installed 3G's shouldn't need a cable upgrade unless you are upgrading the 3G to one with much more amperage.
95->160A would definitely qualify
The major issue is that the 2G harness can't begin to take the current that a 130A alternator can put out, nor is it fused. If the regulator went in the 3G it could melt the 2G trucks wiring harness.
Old 06-10-2011, 07:06 AM
JeffNJF150's Avatar
JeffNJF150
Looks like i may need the alt ASAP and cant wait for shipping, what vehicle would the 130A sidemount come from? Hopefully one of the parts stores has one in stock
Old 06-10-2011, 12:15 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Later E or F series with a smallblock.
Quick Reply: How to tell the difference betweeb stock altenator and 3G?
