Need some advice.... - Ford Truck Enthusiasts Forums
Old 06-09-2011, 11:21 AM
OutbackF100 OutbackF100 is offline
OutbackF100 is starting off with a positive reputation.
I would like to install an AC unit on my 1956 Ford F100 with a 6 cylinder motor 223. My question is does anyone have any options for the compressor brackets?
Old 06-09-2011, 01:29 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
Putting ac on that engine might lead to cooling problems. Fan shroud would be a must. Alan Grove makes brackets for many applications. I'd try them. Good luck with that.
Old 06-10-2011, 03:51 PM
53pickemuptruck's Avatar
53pickemuptruck 53pickemuptruck is offline
53pickemuptruck is gaining momentum as a positive member of FTE.53pickemuptruck is gaining momentum as a positive member of FTE.
Vintage air has their own brackets you can order with a kit.
Old 06-10-2011, 04:42 PM
low54's Avatar
low54 low54 is offline
low54 is starting off with a positive reputation.
dude...roll the windows down and give the money to the poor...are you kidding......that engine is not equiped for air...give ourself a pat and give th change to the poor and needy...love ya...
Tags
1956, 1960, 223, ac, brackets, compressor, cylender, cylinder, cylnder, f100, ford, mount, queston
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
