03 f150 xlt A/C blows out defrost
Old 06-09-2011, 09:46 AM
handyandy91's Avatar
handyandy91
handyandy91 is offline
My 2003 f150 blows the a/c out the defrost when you give it gas when you let of the gas it goes back to the pannel.
I belive it is a vacume leak some where, I looked under hood, behind battery, and traced out everything I could find under the hood up to the firewall, where else should I check, I have the three ***** you turn for control is there something that fails where they are??
Please help
Old 06-09-2011, 09:46 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Go to the HVAC section and see the FAQs.
Old 06-10-2011, 05:48 PM
handyandy91
update
thanks for the info, I found the vacume leak right behind the battery, right where yall said it would be. A small section of solid line was all melted, I guess this happened when I left my battery cover off for a few months(this was stupid all it did was cas stuff to rust and corrode quickly from the extra battery gasses. Cover back on and leak fixed.
Thanks again.
Holmesuser01
04-11-2014 07:51 AM
mshargrave23
09-15-2013 12:02 PM
shakebaker69
1997 - 2003 F150
09-03-2013 06:13 PM
pickupman2002
09-24-2012 02:37 PM
05 f250 6 inch lift
09-15-2010 08:13 AM
Quick Reply: 03 f150 xlt A/C blows out defrost
