How many quarts of tranny fluid?
06-09-2011, 07:01 AM
I just dropped my pan, and I am worndering how many it will take to refill i didnt drain the TQ. Thanks
06-09-2011, 07:19 AM
8-9.
BTW - the torque converter really can not be drained.
06-09-2011, 09:17 AM
Pulling the drain plug and changing the ext. filter I take 8 qts. exactly.
06-09-2011, 10:16 AM
what happened with the trannyleak what was it
sounds like you got it going again
06-09-2011, 10:49 AM
Quote:
Originally Posted by
69cj
You will get a little more out when dropping the pan - assuming you remove the filter.
06-09-2011, 12:30 PM
bismic
Agreed Mark. However unless there's a problem I have no idea why anyone would drop the pan unless their bored and need something not important to do.
06-09-2011, 01:10 PM
Tyler must have been bored! I have only drained mine via the drain plug. It was very convenient to have it!
06-09-2011, 01:23 PM
I wish I had no reason to drop the pan on this 100 degree day.
I had a really bad leak from the pan gasket. I think I accidently over filled the transmission, and caused that seal to start leaking.
06-09-2011, 07:26 PM
I don't understand how overfilling the transmission would cause the pan to leak. Contrary to popular opinion, overfilling does not raise the pressure inside the transmission.
06-09-2011, 08:02 PM
Mark Kovalsky
Agreed, It should blown out the fill tube or O ring on the fill tube. I should have used the term expanded rather than blow.
06-09-2011, 09:25 PM
It very well could have been leaking from the fill tube. Since that the side it was coming from.
But on the other side i had a small drip coming from a bolt.
Anyways, I put the new filter in and the new gasket and the old one was suck a pos gasket compared to the new one.
The leak is all set. But I'm really starting to get hard hard shifts. I think my tranny is starting to go bad.
06-10-2011, 09:13 AM
What type of fluid did you use. Use only Mercon SP or LV. Do you have a tuner? They can also be bad for the TorqueShift tranny.
Jmatthews
06-25-2022 09:29 PM
dbdbb
1966 - 1977 Early Broncos
04-22-2017 10:09 AM
dsquared
02-09-2017 12:56 PM
DDT11
2017+ Super Duty
09-10-2016 04:31 PM
twister2gt
03-08-2009 08:02 PM
07 ,
2003 ,
2007 ,
60 ,
60l ,
courts ,
f250 ,
fluid ,
ford ,
qts ,
quarts ,
qyarts ,
tranny ,
transmission ,
v10
