Code P0299 Turbo Underboost
Old 06-08-2011, 11:24 PM
gladiator4113's Avatar
gladiator4113
gladiator4113 is offline
can anyone help me out with this code P0299 i have read in the forums and see alot of different issue on this so now i really hate going to the dealer but if i have no choice then i dont,, so i come to you the experts for some help i have a 2004 f350 superduty 6.0 4x4 with afe air intake, edge with atitude, since i bought it brand new no problems except the egr cooler ouch!!! lol,, i have 106000 mi on it!! is the turbo still under warranty i dont have the extended warranty i had 5yr 100000 what kind of damage am i looking at $$$$ is there another way to fix this???
thank you in advance for your help
Old 06-09-2011, 10:27 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L forum.
Old 06-10-2011, 02:40 PM
Bkiggins's Avatar
Bkiggins
Bkiggins is offline
It needs cleaned, I was told to drive it like you stole it and it helped but I still had it pulled and cleaned.
Old 06-10-2011, 07:39 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
p0299 caN be caused by lots of stuff
do you still have the stock air intake its a good one
is the air filter clean
start with the easy like cac boots check for hole,
can you hear any hiss/air leak Ypipe flex joint area
check cac tube if its a plasic one may have a crack
clean turbo
can you monitor vgt and boost psi
and welcome to FTE lots of great info check the tech folder too
https://www.ford-trucks.com/forums/3...ch-folder.html
click here^^^^^^^^^^^^^^
Mark_in_co
11-16-2016 08:58 PM
ckwood3
1999 to 2016 Super Duty
10-11-2016 11:40 PM
Vole
09-05-2016 02:50 AM
Orangeoutlaw
02-16-2016 11:51 PM
rmcdonald72
02-05-2014 08:05 AM
Quick Reply: Code P0299 Turbo Underboost
