Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-08-2011, 08:36 PM
entheogenist entheogenist is offline
Garage is empty, add now
entheogenist is starting off with a positive reputation.
Tire rod ends. What do I need before getting started?
Hi
I'm changing tire rod ends on my ford escort. (96)
First time to change a set. What do I need to know
also, will i need any special tools, etc for the job?
thanks
  #2 (permalink)
Old 06-08-2011, 11:51 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Tie rod ends. Your car is rack and pinion, right? So they really aren't "tie rod" ends, but serve the same purpose and NAPA calls them tie rod ends anyway.
You will need a tie rod seperator to get them apart. You may get another post with the exact tool needed, or need to do more research about which one to use on that vehicle.
Automotive Tools - Tie Rod Separators
Then you need an alignment to set the toe and center the rack. If you can keep the rack centered doing this, that would be better.
Is the rack in good condition?
Tags
car, change, end, ends, escort, explorer, ford, mountaineer, required, rod, tie, tier, tire, tool, tools, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
