Help no logic input voltage going into ficm - Ford Truck Enthusiasts Forums
Old 06-08-2011, 05:22 PM
togie's Avatar
togie togie is offline
togie is starting off with a positive reputation.
2003 6.0 friends truck had stereo stolen they didn't trash it too bad but since then it will not start I have no logic input voltage to FICM if I give it voltage at the 10a fuse the FICM puts out a nice 48 volts and starts fine as soon as I take away power dead I have tried darn near everything to trace the this circuit and am now plum outta ideaers
Old 06-08-2011, 05:42 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
It runs to the FICM relay and should energize when that relay energizes. Do you have that diagram? it's a fairly simple circuit.
Old 06-08-2011, 06:07 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Here's a diagram I drew up to help a guy get a 6.0l running in a Ranger. The pin locations may be different, but this will give you a general idea of how the power is coming and going.
Old 06-08-2011, 06:36 PM
togie's Avatar
Thank You I will give it a go with the new info. Still don't think it's fair to bring electrical stuff to the guy who don't drink.
Old 06-08-2011, 06:38 PM
Also Google 6.0l FICM Guide. Good info in that PDF.
On edit, here's a link.
Old 06-08-2011, 06:59 PM
togie's Avatar
Well I now know that I have no power going into relay to engage it the chase goes on
Old 06-09-2011, 06:55 PM
togie's Avatar
anyone have anyideas where the power feed for the ficm relay comes from and if so could this be controled by ford security system
Old 06-09-2011, 07:12 PM
Quote:
Have you checked the 50A fuse that feeds it? I can't attach this PDF I have of the engine electrical.....grrrrrrr
PM me your email and I'll mail it to you
Might be able to see it here: http://www.backglass.org/duncan/ps60...l/ps60_091.jpg
Old 06-09-2011, 07:19 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
check fuse f2-22 and the wiring to the fan clutch
Old 06-09-2011, 07:20 PM
Quote:
WTF took you so long--LMAO
Old 06-09-2011, 07:22 PM
cheezit's Avatar
man it been rough. I have not pulled the wiring diagram but its pretty simple. the ficm relay has to power polls and 2 ground polls just figure out wich of the 4 is missing and trace backwards.
Old 06-09-2011, 07:28 PM
I know it's been hotter than a bitch wolf in a pepper patch there and not much cooler here. Is f2-22 the 50A fuse?
Old 06-13-2011, 06:53 PM
togie's Avatar
This truck is going to drive me nuts I have ignition power to ficm the wires from ficm output to ficm relay are good however I get no output from ficm to engage the 50a relay is it possible that the Gold remote start/theft system maybe messin with me
Old 06-13-2011, 07:19 PM
cheezit's Avatar
the relay has 4 pin what pin on the relay exactly is not got power. look at the bottom of the relay for the relay pin number.
Old 06-13-2011, 09:23 PM
togie's Avatar
thanks for the help I am not sure what the pin number is it is the on closest to the firewall that receives the voltage from I beleive pin 27 or there about on the ficm I have checked the wiring from the ficm to the relay and it is good I am told that the truck ran fine before it was broken into and the stereo stolen I am looking hard at the alarm system right now. If per chance my friend is yanking my chain in an effort to have insurance fix his truck I may explore other uses for the 48 volts from the FICM
Question On FICM DTC (P0611) Rusty Axlerod 6.0L Power Stroke Diesel 13 01-15-2016 06:48 PM
2007 6.0 no power to ficm softpickle 6.0L Power Stroke Diesel 8 02-15-2015 12:58 AM
2006 FICM no power issue dorseyranch 6.0L Power Stroke Diesel 37 02-07-2015 01:49 PM
P1378 FICM supply voltage low egregg57 6.0L Power Stroke Diesel 11 04-24-2014 09:05 PM
04 6.0 cut off while driving.crank no start. TL53ford 6.0L Power Stroke Diesel 5 12-22-2012 11:06 PM
Tags
05, 2006, 60, diagram, f250, ficm, ford, logic, power, powerstroke, radio, supply, voltage, volts, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
