Mass air conversion from speed density
Old 06-08-2011, 03:52 PM
wreckless93's Avatar
wreckless93
wreckless93 is offline
last winter i purchased a 94 F-250. since that time i have replaced trans and done alot of mechanical work to the truck. about a month ago i pulled the motor because it was burning oil, and making an odd screeching noise through the exhaust. I figured while it was out i would make some altercations to the motor ( cam, intake, flat top pistons ect.) well after calling summit and doing some research i found out i am stuck with a "speed density motor" and to make the altercations i need to wire in a MAF sensor. Correct me if im wrong. But this means i need a new ECM? And my trans is the E4OD. so what is my solution? I want to go big with this motor but i cant without a new computer? If someone has any idea what im talking about please give me so clues as to what i should do. The machinest said the motor has to be bored over. Can i even do that? Seems like these speed density motors arent the best to build. If u can help i would appreciate it, thanks
Old 06-08-2011, 04:21 PM
redneckin2010's Avatar
redneckin2010
redneckin2010 is offline
you didnt state which engine you currently have, but being a 94 f250 i would say 351? if you do have the 351, in order to do engine upgrades it will need to be maf due to the sd system not fluctuating with engine needs. the best thing to do is find a 94 or 95 302 and take its comp, harness and maf sensor. when looking for a computer make sure you find one that is for the e40d, some trucks had the 4r70 trans and its not the same.
this link will tell you what comp you need- Ford Fuel Injection » EEC Program Codes
the speed density is not "stuck" to that engine, its just the computer style. so once converted to maf you can add your mods and maf usually adds power also.
Old 06-08-2011, 06:39 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Yes, you can bore the engine over. You can build the engine however you want, but if you get too wild on the cam, compression, or higher than stock displacement, you won't be able to run the speed density computer system. You will have to switch to mass air.
There are a bunch of threads on this forum relating to MAF(mass air flow) conversions, so you might try finding a few of them and reading through just to gain knowledge on the subject.
Here is a little more reading on the subject to pick through.
Ford F-150 Mass Air Conversion - FordMuscle
If you have a a 351, this harness might work for you. Ford Fuel Injection » OBD-II E4OD Mass Air conversion
Old 06-08-2011, 08:09 PM
wreckless93
i read through about 5 posts. and the confusing part to me is, say all i want to do is put as big of a cam as i can go ( without converting). I called summit and they said they dont carry one. it is a 351 W. also cant i bypass all of this by switching to a carb and buying a trans controler? i had a buddy who did some major mods to a 69 351 W and put it in his 95 f-150. The cost was far from cheap so i just want the most cost efficient option. thanks for your replys
Old 06-08-2011, 09:07 PM
Conanski's Avatar
Conanski
Conanski is offline
Summit sells lots of SD friendly cams, the Comp cams 35-512-8 and 35-349-8 are a couple good ones that will really wake the motor up without upsetting the stock computer.
Old 06-08-2011, 09:12 PM
lasg4's Avatar
lasg4
lasg4 is offline
How much vacuum does your engine pull at idle with the cam you have in it?
Old 06-09-2011, 11:43 AM
BearFootCustom's Avatar
BearFootCustom
BearFootCustom is offline
Can you actualy notice the power increase with one of the comp cams?
Old 06-09-2011, 04:08 PM
Conanski's Avatar
Conanski
Conanski is offline
The Comp 35-349-8 makes 16" vacuum at idle.
Old 06-09-2011, 04:09 PM
Conanski's Avatar
Conanski
Conanski is offline
The stock camshaft is by far the biggest restriction on these motors.
Old 06-09-2011, 04:33 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,157 Likes on 915 Posts
No, not really. It's all a scheme. Paul holds that patent on that cam grind, he gets a commission on every one that is sold.
j/k
jimkleiser
13
07-27-2017 03:13 PM
hambone460
04-04-2017 09:23 PM
Jonathan Guerra
10-01-2016 07:04 AM
Middleagecrisis
07-29-2016 06:05 PM
Tdvjensen
29
04-10-2007 12:25 PM
Quick Reply: Mass air conversion from speed density
