couple random questions
ok got the pump in and like usual theres a ton of air in the system, 30 miles later its taking its sweet time.. i reused the gasket becuase joey said i could if it looked ok, sure does! if it was bad will it cause a leak of some sort internally? long cranks still, when cold its not as but but as of 5 minute ago it litterally wont start. didnt have the issue before the swap.
new ipr orings and the res is up to the top, the oil will flicker but i dont see it bubbling? cps works, no dead fuses and chip is solid in there. wtf mang!
guess ill wait a good few hours for the oil to cool(90* out...) and give it another go?
Mine took about 100 miles or so to get the air all out. Closer to 150 I think. If your res is staying full I'd think there wouldn't be any internal leaks. I'm no expert either though. Mine never was quite hard to get going for a while but would always catch. I think you still just got a lot of air to work out. Gotta get it fired up and run it hard or for a good distance and get it back to normal!
I fill the reservior, crank maybe 10 seconds, then crack one of the oil plugs on the heads to vent the air and pull oil down from the reservior, then repeat the process until oil comes out the plugs on both heads. Then it starts easy every time in my experience. I've swapped injectors and hpop a few times and never had an extended crank or start problem following this process.
Thanks,
