decoding the rear end tag. - Ford Truck Enthusiasts Forums
Old 06-08-2011, 12:37 PM
Green Griffin 420's Avatar
Green Griffin 420 Green Griffin 420 is offline
Green Griffin 420 is starting off with a positive reputation.
Can some one tell me what all the numbers on my rear end tag mean. Is it useful information of is it just a part number?
Top line is S847F (the S may be a 5)
Bottom line is 3L55 88 4021
Old 06-08-2011, 01:05 PM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
This sounds like a job for NumberDummy!
Old 06-08-2011, 01:15 PM
I've been searching some since I posted this. It looks like the 3L55 stands for a 3:55 gear with a limited slip differential.
I'm guessing that the 88 stand for a 8.8in rear end. Mine is a 10 bolt.
Old 06-08-2011, 01:18 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Yep its a 3.55 LS
Old 06-08-2011, 02:43 PM
Thanks Lew52.
what does the S847F and 4021 stand for?
Old 06-08-2011, 02:54 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The info in this thread might help decipher what the other alphanumerics are: Ford Ranger Rear Axles - The Ranger Station
Old 06-08-2011, 03:43 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
One is a build date and I forget what the other one is. You've already got the most important pieces of information off the tag.
Quote:
GM guy in this thread
Old 06-08-2011, 05:52 PM
i thought the exact same thing!
Old 06-08-2011, 06:14 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The S847F says it was made at the S=Sterling Plant and the 847F is the application code for the type of Ford it was used on and how much the axle can hold.
It is also a 3.55:1 ratio limited slip 8.8" rear end.
Your date code is not right at it says it was made on the 21st day of the 14th month of 1994.
Tag decoding :
3L55 88 99H06
Second part is the axle ratio: There should be a "3L" preceding the 55 if it's a Limited Slip. If it's open, it would just say '355' .
4th is the ring gear diameter, in your case an 8.8 inch.
5,6,and 7 are the build year, month, and day, in this case, August 6th, of '99. (9=1999, H=8th month [and there is no 'I' in the sequence]) and '06' is the 6th.
Old 06-09-2011, 12:03 AM
Awesome thanks.
It's not really acting like a limited slip rear. I guess I need to change the rearend fluid and conditioner. On the other hand it would explain why it wont burn the tires when I punch it.
Old 06-09-2011, 08:10 AM
rla2005's Avatar
The clutch packs are known to wear out. You can get replacements from many online vendors. For a few $$ more you can upgrade to the kevlar model. A simple fluid change is probably not going to fix your problem.
Old 06-09-2011, 09:29 AM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
Awesome thanks.
I was wondering the same thing, cool to know I have a limited slip and not open.
I thought it was just low on power, but since my truck's been at the tranny shop this week and I'm driving my dads '00 Jimmy, that makes my truck feel like a sports car!
Old 07-21-2012, 03:58 PM
captrick captrick is offline
captrick is starting off with a positive reputation.
how about decoding this tag
WCD-E
300 4MD 403
Old 07-21-2012, 06:43 PM
subford's Avatar
Quote:
WCD-E
300 4MD 403
WCD-E:
1965 Thunderbird
3.00 Ratio
39 teeth R.G.
13 teeth P.
9.0 Dia of R.G.
NL
28 Axle shaft splines.
Old 07-21-2012, 09:33 PM
Thank you very much
Ford 9 inch rear end tag sonny1965 1961 - 1966 F-100 & Larger F-Series Trucks 3 04-17-2014 05:26 PM
#'s on rear-end SportCustomWalt 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-26-2008 10:39 AM
what gear ratio rbloodhound 1999 to 2016 Super Duty 6 06-02-2007 08:27 AM
rear end tag numbers fordman300 Clutch, Transmission, Differential, Axle & Transfer Case 1 04-11-2004 09:24 PM
Rear End Tag Palumbo 1999 to 2016 Super Duty 4 12-01-2003 01:12 PM
Tags
355, 3l55, 3l5588, 88, bronco, decode, differential, end, ford, gear, number, numbers, product, rear, tag
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
