55F100 modified frame - Ford Truck Enthusiasts Forums
Old 06-08-2011, 09:48 AM
CdnWillyG's Avatar
CdnWillyG CdnWillyG is offline
CdnWillyG is starting off with a positive reputation.
I need the goods on this topic.
In another thread here there was a clearance issue withthe exhaust and the original motor mount crossmember located under the firewall and the advise was not to mess with it.
On my frame this has been removed and is running a boxed Mustang ll IFS with a support installed to hold the T5 tranny.
Looking at other modified frames on this site and new repo frames this crossmember has been removed or not installed.
I guess my question is it okay to leave this out?
Old 06-08-2011, 09:55 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
IMHO, in your case, you are fine. The MII crossmember and boxing takes the place structurally of the original crossmember removed. You've changed the load dynamics to that of a modern vehicle, and you should have no troubles. I'll also add that in your pic, it looks like yours is done better than most. Nice job.
Old 06-08-2011, 09:59 AM
Okiedokie's Avatar
Okiedokie Okiedokie is offline
Okiedokie is starting off with a positive reputation.
Boxed mine back to the cab mounts. No problems. Nice looking frame.
Old 06-08-2011, 07:02 PM
CdnWillyG's Avatar
That's good news and what I was hoping would be the answer.
Not sure how successful I would have been trying to find that crossmember.
Thanks for the comments on the frame.
Old 06-09-2011, 09:57 AM
thepitshop's Avatar
thepitshop thepitshop is offline
thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.thepitshop has a great reputation on FTE.
frame`s looking good! i`d remove the crossmember
Old 06-09-2011, 10:04 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
The original crossmember counteracts the rotational forces applied to the frame by the front cab mounts. It was by design not chance that this crossmember was placed in line with the front cab mounts. If you can stand on the cab mount "wing" and there is no flex in the frame at that point then you should be OK.
Old 06-10-2011, 01:05 AM
CdnWillyG's Avatar
Thanks for the input!
I will move on with the build...back to getting the doors straight and the gaps even.
2wd to 4x4 conversion different direction.. thoughts tubolove 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-16-2010 09:23 AM
Industrial Chassis Dakota IFS Crossmember AZAV8 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 10-30-2009 02:12 PM
Loud Popping / Craking Noise Gone 93Mule 1978 - 1996 Big Bronco 4 08-22-2007 01:22 PM
called in sick, finally got crossmember removed. 52'F-3 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-10-2007 09:01 PM
60' frame modifications? jaymoford 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-07-2004 08:54 PM
Tags
f100, f150, frame
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
