Hard 1-2 shift
That's a thread hijack if I've ever seen one!
Your problem is completely different because it doesn't shift harsh all the time. Yours is shifting harsh once the OD light flashes because the transmission is in limp home mode due to an error code being stored in the PCM. You need someone with the right scan tool to read the code so we know where to start.
About to dig in...
So I have been reading this thread and I am about to attempt to fix the 1-2 shift problem.
I have previously dropped the pan, removed the accumulator body and found the Line pressure modulator valve per the Sonnex diagram and found a local Sonnex dealer for the part.
Link to doc: http://www.sonnax.com/system/announcement/96948-05K.pdf
Two questions:
1. How do you remove the actual valve? I was able to remove the retainer clip, but the valve did not come out and I did not want to force anything.
2. Mark Kovalsky sez "Make sure all are free and no springs are broken." How free should they be? I tried pressing them with my fingers. Some moved about 2mm and some did not move at all (without removing their clips).
Concentrating on the one in the diagram, it seems to move freely within the shaft when I remove the clip, but it does not come out.
Thanks for the help with this.
Homie
Two questions:
Homie
You are trying to move the plugs, not the valves. With a small pick you can reach in the passages to move the valve. Pushing on the plug doesn't mean anything.
Thanks Mark...
I see the threaded hole on the right cylinder in the diagram. I will try removing that one.
But what about the one on the left? It looks like the sonnex part is the one on the left in the diagram. I removed the "M" retainer clip, but the rest of the valve, etc., does not come out.
I'll probably run and get the parts today and tomorrow and start the work tomorrow.
Thanks for your help. cheers
2015 f250 6.7
Hi Mark. I am hoping your still around on this thread…. But I have a 2015 6.7 f250 it’s deleted. But under minimal acceleration I have a very hard shift into second. No other gear is effected but like others when I get into it it shifts perfect. But like I’m traffic and I hit the peddle a little and let off man it slams hard. Think it’s the same thing?
Shift Concerns: Harsh (some or all)
Possible Component Reference/Action 214 — ROUTINE Powertrain Control System
- PCM (gasoline engines), Transmission Control Module (TCM) (diesel engines), external vehicle harness, transmission internal harness, Shift Solenoid A (SSA), Shift Solenoid B (SSB), Shift Solenoid C (SSC), Shift Solenoid D (SSD), Shift Solenoid E (SSE), Pressure Control Solenoid A (PCA),Turbine Shaft Speed (TSS), Output Shaft Speed (OSS) or Transmission Fluid Temperature (TFT)
- CARRY OUT the Key ON Engine OFF (KOEO) and Key ON Engine Running (KOER) self-test. READ and RECORD the DTC(s). Go to the appropriate pinpoint test for that DTC. REPAIR as required. CLEAR the DTCs. TEST the vehicle system for normal operation.
- Main control contaminated, solenoid(s) damaged, solenoids stuck or bore damaged
- INSPECT for damage and/or contamination. Manual valve damaged, stuck or bore damaged
3cv
09-04-2016 09:07 AM
