distributor cap 49 ford - Ford Truck Enthusiasts Forums
Old 06-08-2011, 12:14 AM
bobsjoint420's Avatar
bobsjoint420 bobsjoint420 is offline
bobsjoint420 is starting off with a positive reputation.
Anyone out there have any problems getting the right cap for your flathead? I bought a new cap and rotor at o'reillys and when i installed them as sood as i started it the rotor snapped in half, so i put the old rotor on and it snapped that one too. I took the cap and broken rotor back to o'reillys they gave me a new rotor and wanted to give me the same cap because thats what it calls for. I told them to keep the cap because it must be the wrong size. Anyone have any thoughts on what cap to get and where? They are really not that much help any info would help. by the way the flathead is in a 49 ford f3 if it matters.
Old 06-08-2011, 07:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
FAB-12106-A .. Flathead & OHV V8 Distributor Cap (Motorcraft DH-1).
SOEBY MOTOR CO. in Walhalla ND has 1 = 701-549-3711.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 7 = 606-787-5293.
Applications: 1948/56 Trucks & 1949/56 Passenger Cars.
FAA-12200-B .. Distributor Rotor (Motorcraft DR-1).
PIONEER FORD in Groton SD has 2 = 605-397-2311.
WOLFE FORD in Lidgerwood ND has 4 = 701-538-7337.
GREEN SALES CO. has 239.
Applications: 1948/56 I-6 & V8: Trucks & 1949/56 Passenger Cars / 1957/64 223 I-6: Full sized Ford Passenger Cars / 1957/64 F100/600 223 I-6 / 1960/67 Falcon/Fairlane/Comet/Mustang 144/170/200 I-6.
Old 06-08-2011, 09:26 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
NAPA shows it too
https://www.napaonline.com/Catalog/C...+50028+2028079
Beware, they have two they carry, one with aluminum contacts or this one with brass. Brass is better. The NAPA p/n is Echlin FA78 if the link doesn't work
Is the part OReilly's gave you a BWD p/n C147? That's what their e-catalog shows as fitting.
http://www.oreillyauto.com/site/c/de...0413&ppt=C0334
Old 06-09-2011, 08:53 AM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
ross, good call on using brass. the napa line of brass from echlin is pretty good.
Old 06-10-2011, 11:41 PM
thanks alot guys the OReilly one was a bwd c147 with brass contacts and it snapped both rotors it doesn't fit on there right it was hard to get it snapped on so anyone who needs one don't get it from there.
4.9 Distributor install TDC question Boss08v10 1987 - 1996 F150 & Larger F-Series Trucks 12 07-10-2015 05:46 PM
Really need help! Tried searching. Nealva 1987 - 1996 F150 & Larger F-Series Trucks 8 12-19-2014 07:27 PM
Tune up for a 330 TheOtherStyle FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 10-25-2014 08:48 PM
Ignition system upgrades? techningeer 1987 - 1996 F150 & Larger F-Series Trucks 7 06-08-2014 01:02 PM
brake rotor question joshofalltrades 1987 - 1996 F150 & Larger F-Series Trucks 8 03-05-2013 02:39 AM
Tags
12200b, dr, dr1, echlin, fa78, faa, faa12200b, motorcraft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
