Tires on Stock 04 f150 18'' wheels - Ford Truck Enthusiasts Forums
Old 06-07-2011, 10:24 PM
ajs111 ajs111 is offline
ajs111 is starting off with a positive reputation.
I am going to put a 2.5'' leveling kit in. I plan on getting a set of 33'' tires but i don't know how wide i can go with the stock 18'' wheels. And on any wheel how wide can you go w/o having to get new wheels
Sorry if this is a beginner question but I can't find too much info on it. Thanks.
Old 06-07-2011, 10:34 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Typically you want to stay within 3-4" max of the width of the tire to the width of the wheel. Sure you can fit wider, but they could wear strangely.
The 18" wheel is 7.5" wide if I'm correct, hell maybe 8", having trouble remembering. You'd be fine with a 285, 295, or even a 305 width tire on that stock wheel.
Old 06-08-2011, 11:51 AM
triple8 triple8 is offline
triple8 is starting off with a positive reputation.
i run 305 65/18 BFG's on my stock rims. not sure if i could go much wider. the inner side wall is about a 1/2" for the upper ball joint. truck has a 2" leveling kit
Old 06-08-2011, 07:44 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
I have 285/65/18's and there is no issue what so ever. The next time I get tires I will be going to 295/75/18's.
Old 06-08-2011, 09:59 PM
Thanks for the info. I kinda came to the realization that i need knew wheels. I want them to stick out an inch or two. I've done some research on offset and backspace but i can't really rap my head around it. can you just explain it as simply as possible or even better could you just point me into the direction of what type of rims i should get
Old 06-09-2011, 06:29 AM
MCDavis's Avatar
For about $650 you could get safe wheel spacers and keep your stock wheels.
Old 06-10-2011, 07:27 AM
dos0711's Avatar
dos0711 dos0711 is offline
dos0711 is starting off with a positive reputation.
Quote:
Same here. No problems.
Old 06-14-2011, 09:39 PM
mattsautobody442's Avatar
mattsautobody442 mattsautobody442 is offline
mattsautobody442 is starting off with a positive reputation.
is there a metric equivalent?
Old 06-15-2011, 06:56 AM
Quote:
most of the input above IS metric related?
How wide are my rims? willtim1234 1999 to 2016 Super Duty 2 08-03-2014 05:45 PM
Wheels and Tires rpaxton939 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-27-2014 01:40 AM
How wide is to wide? thendrix 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-03-2010 11:41 PM
Wheel Width ???? ozark1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 06-30-2007 10:06 PM
17" or 18" wheels on new F250 ? gdb1960 1999 to 2016 Super Duty 5 11-27-2004 11:13 AM
Tags
18, 20042008, 2006, 2008, discount, f150, ford, forum, offset, rims, spec, sport, stock, tire, tires, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
