maintenance schedule - Ford Truck Enthusiasts Forums
Old 11-19-2014, 02:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Old 06-07-2011, 07:06 PM
the winemaker the winemaker is offline
the winemaker is starting off with a positive reputation.
Smile maintenance schedule
I hgave a 2003 f350 6.0 lt deisel what is the thoughts on when I should change oil,,fuel and external tranny filters..thanks..winemaker
Old 06-07-2011, 07:17 PM
JESTERxHEAD JESTERxHEAD is offline
JESTERxHEAD is starting off with a positive reputation.
Well...I know the oil change interval is different from one person to another but I feel like the oil starts going down hill after 5k. so I change mine every 5k miles.
Fuel Filter every 10k (every other oil change)
Trans filter Every other fuel filter change (20k)
I know that may be a bit excessive but my 03 6.0L treats me good in return.
Old 06-07-2011, 10:22 PM
colo_dually's Avatar
colo_dually colo_dually is offline
colo_dually is gaining momentum as a positive member of FTE.colo_dually is gaining momentum as a positive member of FTE.
Typical Breakdown for me is as follows:
Oil - 5-6k Reg (Syn 7-8k unless you're running a pypass filter and testing it)
Fuel Filters - Every other oil change or 12k
Transmission - Fluid and Filters 30k
Air Filter - 45k
Coolant -50k
Anything else is on an as-required basis. (Oil Cooler rebuild, tires, brakes, etc.)
Old 06-08-2011, 07:52 AM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
If you don't already have one check out the maintenance schedule at the following website. It will provide a complete breakdown of maintenance intervals for your vehicle.
https://www.flmowner.com/servlet/Con...e&ord=40856088
Old 06-08-2011, 01:03 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Quote:
Originally Posted by colo_dually View Post
Oil - 5-6k Reg (Syn 7-8k unless you're running a pypass filter and testing it) (I agree)
Fuel Filters - Every other oil change or 12k (between 10,000miles and 15,000miles I have changed mine at 10,0000 the set I am on now will be changed at 12,000, I will also be changing them at 12 from now on due to price of the filters, I want to get more of my moneys worth)
Transmission - Fluid and Filters 30k (check out my link)
Air Filter - 45k (good, or sooner ig the restriction gauge tells you)
Coolant -50k (I would rather get a coolant filter and do a very good flush, and go longer.)
http://www.powerstroke.org/forum/6-0...-7-quarts.html
http://www.dieselfiltersonline.com/f...k-filters.aspx
http://www.ford-trucks.com/forums/10...l-filters.html
Old 06-08-2011, 02:00 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
My thoughts,
Oil = 5k miles, using synthetic, with a few UOA to make sure the viscosity is holding up.
Fuel filters = 10k miles, but the truth is that our fuel is so clean that I'm throwing away perfectly good filters.
Transmission = 30k miles fluid change, using hot flush machine at the dealer, with external filter change ever other time (60k). Pan is never opened.
Air filter = when the filter minder says, but I changed mine at 75k because I was tired of waiting around for the message.
Coolant = 50k, complete flush and change. I don't bother testing it thus far, since it should easily last 50k.
Differentials = 50k on the rear. On the front I just do a finger tip check on the condition. Doesn't get used that much.
Transfer case = 50k
4WD U-joints = 10k (ever other oil change)
Power steering fluid = 50k (but it actually was at 30k and again at 80k)
Brake fluid = 50k (but I'm way past due, still on the original)
Old 06-08-2011, 04:52 PM
Groodman Groodman is offline
Groodman is starting off with a positive reputation.
I've been using motorcraft 15W 40 in my truck since new and changing every 5,000 miles or so. Is there any reason why I should/should not switch to a full synthetic oil(Rotella T6 5W-40) at this point? My truck has about 93,000 miles on it. I'm worried that I may develop new oil leaks or cause any small leaks to get worse. Anyone have this occur as a result of switching this late?
Old 06-08-2011, 05:00 PM
Quote:
I switched to 5w40 syn just because I like synthetic oils but most of all it helped in the wind whipped cold winters....
Old 06-08-2011, 07:34 PM
MAINTENANCE SCHEDULE
THANKS FOR ALL OF INFO GUYS..i HAVE 10.000 KMS WHICH IS ROUGHLY 6000 MILES ON FUEL FILTER..50000KMS ON AIR FILTER WHICH IS 30000 MILES..i USUALLY CHANGE MY OIL BETWEEN 5-6000 KMS AS i TOW A FITHWHEEL TO FLDA IN FALL..DO YOU THINK i WILL BE OK WITH FUEL FILTER TILL i GET TO FLDA IN NOV AT THAT TIME i WILL HAVE CLOSE TO 9000 MILES ON FUEL FILTER...i HAVE LOOKED AIR FILTER MINDER AND AFTER ALL THIS MILAGE IT DOES NOT SEEM TO HAVE MOVED SINCE i INSTALLED THE NEW AIR FILTER CLOSE TO 4 YRS AGO..WINEMAKER
Old 06-08-2011, 07:42 PM
bpounds's Avatar
2 bit Californian
Quote:
Sure. I don't know anyone who changes them at less than 10k miles. Some guys carry a spare set on the road. Not me, but it's not a bad idea. You never know when Bubba's Diesel Stop will pump your tank full of gunk.
Old 06-08-2011, 07:52 PM
maibtenance schedule
bpounds..tks for reply..any thoughts why the filter minder has not moved alot the air filter has close to 50,000kms/30,000 miles on it and 4 yrs or close old winemaker
Old 06-08-2011, 07:58 PM
bpounds's Avatar
2 bit Californian
They last a long time and hold a lot of dirt. Many of them last 100k miles. Just depends on how much you drive on dirt roads.
It is barely getting started at 30k.
how much can a 6.2 pull with safety the winemaker 1999 to 2016 Super Duty 10 08-10-2016 05:36 PM
steering column parts winemaker69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-24-2012 10:44 AM
Transmission Identifacation winemaker69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-04-2012 04:09 PM
86 F-250 Dash Lights winemaker69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 01-18-2012 11:27 PM
air filter minder the winemaker 6.0L Power Stroke Diesel 9 08-12-2010 11:52 PM
Tags
2003, 2006, 2008, 300000, 60, 60l, checklist, diesel, f150, f250, ford, maintenance, mile, pdf, pick, schedule, scheduled, service, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
