Which Radiator
Which Radiator
I took my 1952 F-1 radiator to the shop to get it cleaned and to get the inlets and outlets converted to work with my 302. All of this was supposed to be about $150. Well the shop called me back and said I needed to re-core the old radiator.
So....
What stock Mustang radiator can I buy at AutoZone Orielly's etc etc that will fit in the original space in the core support?
Bummer
So....
Bummer
I bought this one on Ebay from Superior Radiator. It was listed at $350 with a best offer option...I offered $275 & they accepted. A couple of other guys have done the same since then as well.
They make these on-site in Michigan and will place the hose outlets to whatever you specify. The one in the picture is set up for a small block ford. This particular one also has the transmission cooler incorporated, but you can get one without that if that's what you need.
I bought some new parts from a fellow FTEer some time ago when he decided to abandon his F1 project. One of the things I got was a new Howe Racing radiator that he bought through NoLimit (RADIATOR 1948-52 F-1-No Limit Engineering). The outlets are set up for a SBC. Send me a PM if this might work for you.
Now I know what radiator!
Thanks for all the replies. I looked at mid 70's Dodge truck radiators, then I said what the heck, and look at mid 70's Ford truck radiator. I see lots and lots of choices with the outlets on the correct sides and trans coolers included and for 302 motor. Whahoo
The interesting think is that O'Reilly's the part numbers for 1955, '65, and '75 are all the same radiator and pricing is less than $200.
