You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
she still grabbs the Brakes while driving.... then after a while she releases them. Meaning she *hopps* rathen then drives, Brakes are hot after and smelly but so far no damage done.
She also still has a jerky braking when your trying to stop.
best I can explain it lol
Here is what has been done
Pads, Lines, Rotors, Calipers, all greased and looks good, bleed many Times & Changed Power stearing Fluid.
2 different Shops & 1 Hubby later
she still does it
so we going to replace Boost next. Then the Master ... and if she still does it after all that I sell her and buy a new Truck
<!-- / message --><!-- sig -->__________________
Damn Pat, I don't know about the diesel system. Umm, abs system flaking out? Again, I don't know the diesel system but after all that there can't be much left is there? Main hubs ok? Just guessing.
can you feel anything in the steering wheel when it happens? Do you feel anything in the pedal? is it in the back or the front that it gets hot? Or all 4?
she still does it
I'd check the ABS, can you hear the ABS motor doing anything when you hit the brakes and they pulse? You could try pulling the fuse for the ABS out too that should disable the system and see if it does it still. That's a cheaper test then replacing the booster or master.
__________________
Kevin
99 F350, CC, LB 7.3 PSD, 229k and counting
04 Town Car Ultimate, 130k,
Great suggestions, just sent her off a message to give it a try.
Well I guess I should have found this thread before I posted in the other one. Sounds like everything I suggested has been done.
I would start looking for a bearing locking up, or the proportioning valve/ABS system. If you can smell brakes.
The pulsation is the rotors. Take the stock ones off and throw them in the scrap pile. I have had the best luck with slotted and drilled rotors, never had any pulsation after. Make sure lugnuts are torques correctly and evenly.
Rich
__________________
Hi my name is Rich, I am a cornerholic..........
