Loose side mirror. How to tighten? - Ford Truck Enthusiasts Forums
Old 06-07-2011, 10:25 AM
graphite675 graphite675 is offline
graphite675 is starting off with a positive reputation.
Does anyone know how to tighten the drivers side mirror? It's rattleing around and driving me nuts. It's loose at the pivot point not the door mount. It's the power/folding version.
I looked at it but can't figure out how to tighten it. There is a little plastic access panel on the bottom below the pivot but there doesn't appear to be a nut or anything to tighten in there? Myabe I missed it?
Thanks.
Old 11-21-2016, 01:05 PM
abridges01 abridges01 is offline
abridges01 is starting off with a positive reputation.
Did you ever receive a reply graphite675? I have the same issue, but the washer retaining the spring above the plastic access panel is bust on mine, I need source a replacement and installation instructions
Loose side view mirror issues drakerc 1997-2006 Expedition & Navigator 4 09-10-2016 05:24 PM
Help how to tighten pivot arm bushing bolts? annaleigh 1968-2013 Full Size Vans 13 06-15-2016 10:29 PM
Question About Replacing Upper Control Arm FordTruckChuck 1997 - 2003 F150 22 11-12-2015 07:25 PM
Velvac mirror loose EagleFreek 1968-2013 Full Size Vans 0 10-09-2015 05:45 PM
ignition actuator problem weavemaster 1987 - 1996 F150 & Larger F-Series Trucks 7 11-22-2004 08:31 AM
Tags
2007, 2008, 2010, cars, door, drivers, explorer, f150, fix, ford, loose, mirror, navigator, side, tighten, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
