Flathead engine colors - Ford Truck Enthusiasts Forums
Old 06-07-2011, 10:14 AM
cruisetopdown's Avatar
cruisetopdown cruisetopdown is online now
cruisetopdown has a good reputation on FTE.cruisetopdown has a good reputation on FTE.
Can anyone point me to the factory flathead 239 V8 engine colors for 1952. I have pulled the engine (thanks for the pointers on that) and am in the process of cleaning/de-greasing and glass beading parts and pieces. I would like to keep things as original as possible and want to know what colors go where....... The engine looks to have been a gold/bronze color, but the intake was a silver green color? Any info is greatly appreciated.
Thanks,
Wade
Old 06-07-2011, 02:46 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
Thanks,
Wade
The 52 and 53 truck engines were green. Krylon engine paint "2007 Ford Green" is pretty close, although not exact.
Old 06-07-2011, 03:09 PM
Thanks effie, does everything get the green? (block,heads,intake,w pumps,timing cover,pan)
w
Old 06-07-2011, 03:13 PM
w
Not my engine, but a great example.
It's a 53, I can only assume the color scheme would be the same as a 52.
Old 06-07-2011, 05:46 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
the green as stated above for our trucks, or red (according to Vanpelts) but I've never seen a red one in a 52.
here's the engine after I removed it from my 52 F6 it had a stuck valve on the drivers side that I had to remove the head for fixing. this was running it just after the first torque sequence on the head bolts ( had an old timer tell me to run it till warm or just more than warm without water the first head bolt tightening sequence ) then retorque after cool down.
here is another great flathead resource if you haven't seen it yet?
Engine Colors:
Ford engines were generally dark blue in 1949 and changed to bronze in late '49 production through 1951. For 1952 and 1953 the Ford engine was either tangerine red or green. The Ford truck engines were red from 1948 through 1951, and then changed to green for 1952-53.
Ford Flathead Engines
Cheers
Josh
Old 06-08-2011, 06:48 AM
Thanks for the information guys....I will dive into the glass beading cabinet this weekend to get things cleaned up and painted. I plan on pulling the pan and one rod cap to see what kind of condition this thing is in, hopefully I can just "ring and bearing" her back to life.
w
Old 06-08-2011, 09:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Detroit Diesel Alpine Green, Dupli-Color part number DE1618, is very close too and a little easier to find.
Old 06-08-2011, 10:19 AM
Thanks Ross, I have ordered a couple of rattle cans that you recommended
Would you know the color of the oil canister?, mine looks to be bronze.....
w
Old 06-08-2011, 10:26 AM
ALBUQ F-1's Avatar
postin' fool
Usually black, because they were an add-on. I don't think I've ever seen one engine color.
Old 06-08-2011, 10:55 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Chuck has said the green is 1952 Lincoln green and recommended getting it from Bill Hirsch. I've also read that the Detroit Diesel Alpine Green is a very close match. Here are pics of Mark Mossell's (the chassisman) restored Ranger engine. Mark is a purist's purist, so I'm sure what you see is correct. I took these, but there's a couple others with wider angles over in his Hub Garage gallery. Stu
HubGarage.com - Mark Mossell's Marmon Herrington Garage
Old 06-08-2011, 11:48 AM
Thanks Stu, that is a nice looking engine....I went ahead and bought the Duplicolor green as I am not necessarily trying to build to that level of detail, but do want it to resemble the OEM look.
w
engine number RICHB99 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-04-2017 01:57 PM
Flathead V8 engine color?? Michael.Smith928 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 01-03-2017 07:12 PM
That guy with dumb questions! FuzzFace2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 05-21-2016 10:53 PM
Nice flathead! Chris 56 f6 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 03-06-2014 09:16 AM
Tags
1949, 1952, alpine, bronco, code, color, colors, engine, f1, factory, flathead, ford, green, pictures, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
