Transmission ID & Parking Brake ??'s - Ford Truck Enthusiasts Forums
Old 06-07-2011, 09:35 AM
andgott andgott is offline
andgott is gaining momentum as a positive member of FTE.
Tracing out the cable to the speedometer, I found that it was disconnected under the truck, just kind of hanging there. I'm not sure if it's even the correct cable- I don't know what transmission this is for sure-
Sorry about the bad pic, cell phone camera was all I had handy... If it helps, the lettering on the side reads-
rfg8tp
7a040a
w2
I know that the transmission isn't original- I suspect it's from the 70's sometime.
Also- The parking brake handle in the cab isn't connected to the cable... It APPEARS that everything under the truck is intact, just not connected to the handle. Of course there is nothing in the service manual about it- at least not that I can find.
How do I remove the handle and replace the cable???
Thanks!
-Andrew
Old 06-07-2011, 01:55 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
It's impossible to answer your questions since you made no mention of what your truck is.
What year/series is it? Is it 2WD or 4WD, 3 speed or 4 speed? What is the wheelbase?
The 7A040 number you posted is the ID number marked on the extension housing, but the RF G8TP prefix makes no sense.
The following makes sense, so it could be: C8TP-7A040-A (C instead of G), or D8TP-7A039-A (D instead of G).
Old 06-07-2011, 07:59 PM
It's a '66 F-100, 2wd. BUT, the transmission/engine have been replaced- When it was built it was a manual. It still has a 352 in it, though it appears to be a later one (Blue valve covers w/Power by ford embossing). To be honest, I don't know ANYTHING more about the transmission...
I'll have to try to get a better look at the numbers, I was at a BAD angle when I was climbing around underneath checking out the brakes...
Just what do I need to find on there to ID it? Where will I find it?
Thanks
-Andrew
Old 06-09-2011, 08:47 AM
I got down underneath for a better look... It is a c-6 I think- 17 bolts on the pan... You were correct,ND, the number on it was C8TP-7A040-A, there was some 'crud' on the C that made it look like a G from the angle I was at.
That would be a 1968 Transmission, right?
Now I need to get a new speedometer cable for it- The old one that's dangling there was for whatever transmission used to be in there- And, Of course, Won't fit the new transmission. Hopefully that's all I need to get the speedometer functional!
I got the parking brakes working, too- Just a matter of reconnecting them- the cable was disconnected at the handle. I had to take it all apart to see how it went together- Once I saw it, it was EASY!
-Andrew
Old 06-09-2011, 01:33 PM
From the looks of the speedo driven gear, you will need that too, available from Ford for less than 4 bucks. 16-21 toothed gears are available, count the number of teeth on the original, get the same one.
The original 1965/66 cable w/a 3 speed manual is 64.80" long. With a swapped in C6 trans, I dunno how long a cable you'll need.
1968/72 F100/250 w/a C6 speedo cable (C7TZ-17260-AB): 75.42" long. This same cable was also used in 1967 F100/250's w/the MX Cruise-O.
C8TP-7A040-A = C8TZ-7A039-A .. C6 Extension Housing / 1968 F100/350 & 1969 F100/350 before serial number F33,001.
Old 06-09-2011, 09:02 PM
Thanks, ND... Helpful as usual!
That gear is from the OLD manual transmission- It was just hanging there. Apparently, when they swapped out the engine/transmission, they didn't care if they had a speedometer...
I found the cable at AutoZone, for $15, and now have a functional speedometer! The odometer doesn't seem to be moving, though- So I guess my truck has 70,300 miles on it for life now.
And, despite the fact that the parts counter guy at autozone assured me that there was no such thing as a 302 Ford engine- I MUST mean a 351- I also have a functional engine temp gauge as well... The engine has an Edelbrock intake manifold- So the temp sensor for the 352 was a different size, but we figured out which one I needed, eventually- DESPITE the help I was given by the autozone staff
-Andrew
Old 06-10-2011, 11:54 AM
jimmmack jimmmack is offline
jimmmack is starting off with a positive reputation.
which speedo cable?
I have the same issue with speeedo! what cable did you ask for at the parts store. I ordered two seperate types from LMC both were wrong. My tranny is just like the one in the photo.
Thanks
Old 06-10-2011, 12:47 PM
This is the one that I used-
Pioneer/Speedometer Cable (CA-3004) | 1970 Ford F100 1/2 ton P/U 2WD 8 Cylinders H 6.4L 2BL OHV | AutoZone.com
I had them look up a 1970 F100, w/ Auto. This is the part that it found. The cross reference matched the # that N.D. gave me- so I gave it a shot...
Old 06-11-2011, 07:20 AM
thanks! going to give it a try hope this one is correct
Old 11-17-2013, 08:50 PM
hellonwheelsxxx's Avatar
hellonwheelsxxx hellonwheelsxxx is offline
hellonwheelsxxx is starting off with a positive reputation.
I dont mean to steal your thread but i just bought one of these transmissions for my 76 cleveland and i notice it has a circle bellhousing. Im concerned that isnt goin to work if anybody has any ideas please let me no. I also read somewhere that it may be a mel 462 trans
Old 11-17-2013, 09:41 PM
mikeb's66's Avatar
mikeb's66 mikeb's66 is offline
mikeb's66 is gaining momentum as a positive member of FTE.mikeb's66 is gaining momentum as a positive member of FTE.
Quote:
If the bell housing is round, it's for a 360-390 engine. Will not bolt up to a 351C. You need a Trans from a 300/302/351. That type bell housing will be about the same diameter but flat on top instead of completely round.
This a picture of an AOD, but same bell housing pattern you need.
Old 11-18-2013, 03:47 AM
Thanx mike so is this trans an fe or mel 462 trans having the round bell?
Old 11-18-2013, 09:43 AM
mikeb's66's Avatar
It's an FE. I believe but not totally sure that the 462 was a taller like a 460 or 7.3 but slightly angled at the top.
WTB 3 post west coast mirrors, NOS if you have them or good condition used ones Dace WTB - Parts & other 1 03-07-2014 12:33 AM
Bedside tool box installation andgott 1961 - 1966 F-100 & Larger F-Series Trucks 19 09-10-2013 12:04 PM
'62 C550 COE, Questions... andgott Large Truck 5 07-23-2013 01:52 AM
66 Factory Radio Repair, & Mp3 Input addition andgott 1961 - 1966 F-100 & Larger F-Series Trucks 24 11-15-2012 07:33 PM
My Project andgott 1961 - 1966 F-100 & Larger F-Series Trucks 48 05-11-2012 11:49 AM
Tags
1968, 1973, 7a040, 7a040a, brake, c6, c8tp, ford, id, parking, rf, rfc8tp7a040, speedo, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
