1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 Headlights
Old 06-07-2011, 07:26 AM
04zrx's Avatar
04zrx
04zrx is offline
2011 Headlights
I have a new 20 11 F250 and the headlights are awefull who has a cure for this?
thanks
Old 06-07-2011, 07:37 AM
Super08's Avatar
Super08
Super08 is offline
I was hoping they would be better than the ones on my 09.
Old 06-07-2011, 08:01 AM
jc8825's Avatar
jc8825
jc8825 is offline
How, exactly, are they "awful"?
Old 06-07-2011, 08:21 AM
mach8274's Avatar
mach8274
mach8274 is offline
No problems with mine. I do plan on some HID's eventually though.
Old 06-07-2011, 08:38 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Mine work just fine. If they are not aimed right just fix it, the manual tells you how.
If you don't like the way they look you should not have bought the truck. They are the same as when you ordered or first looked at the truck.
Old 06-07-2011, 08:47 AM
Super08's Avatar
Super08
Super08 is offline
Now you got me thinking. I thought he was referring to how bright they are. I never considered he might be referring to how they look.
Old 06-07-2011, 08:50 AM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
My 09 & 11 headlights work great. Maybe you should adjust them.
Old 06-07-2011, 09:32 AM
Super08's Avatar
Super08
Super08 is offline
I played with the ones on my 09, it is just the way they are. Not near as good as the 05 to 07's were. It may have to do with them being lower now. I also noticed with the lower mounting of the lights on the 08-10 trucks is they are much more sensitive to changes in load (ie hooking to a trailer) than the older trucks were due to the lower angle they meet the road at, when you think about this one it only makes sense due to the geometry behind it.
Old 06-07-2011, 09:57 AM
PsycoJuana's Avatar
PsycoJuana
PsycoJuana is offline
Mine are great! just rolled 10 grand on my 2011
Old 06-07-2011, 10:26 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Yeah I have seen in other threads where people don't like the turn signal on top. If it was I think they would be too high and shine in other drivers eyes. I already get flashed now without a trailer hooked up, I would not want mine higher.
Old 06-07-2011, 04:42 PM
LSchicago2's Avatar
LSchicago2
Prior to 78, Ford's had the head lights on the bottom, and turn signals on the top. They just went back to the old way of doing it.
Old 06-08-2011, 05:45 AM
04zrx's Avatar
04zrx
04zrx is offline
Ok guess I need to be more specific, When I say" they are awefull" Let me rephraze that. You see I drove a 2001 F250 V10 for years Loved that truck! These headlights have a destinct dark line at the top, like they are blocked along the top edge hard to describe. I'm certin the government has something to do with this. The line along the top shortens the distance that the light goes. I have the factory driving lights also and love them.
I checked, and they are adjusted according to the owners manual fine. If I change out the bulbs do you think the black line at the top will go away?
thanks guys.
Old 06-08-2011, 06:44 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
You could try that but I doubt that there is a line on the bulb. The lights are probably hitting the upper portion of the lens, causing your black line. And my guess it is a design issue to keep the lights from shinning in the on coming traffic.
Where do you see the line? On the road? When you pull up in front of a building or wall?
Old 06-08-2011, 06:48 AM
04zrx's Avatar
04zrx
04zrx is offline
the line limits the distance the light travels it's very destinct in a wall but when driving you can see the light just stops black line in the road.
Hate it.
Old 06-08-2011, 07:19 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
I'll check it out tonight.
Quick Reply: 2011 Headlights
