Clutch Bleed on '93 Ranger - Ford Truck Enthusiasts Forums
Old 03-25-2003, 09:15 PM
cpc101 cpc101 is offline
cpc101 is starting off with a positive reputation.
Hi,
I've just replaced the clutch and slave cylinder (M5OD) on my '93 Ranger 4.0l SuperCab. I'm having a problem bleeding the system. I've heard that they can be a pain in the butt.
Here's my problem:
I have two different procedures that totally contradict one another. The first one states that: "Before performing any service that requires removal of the slave cylinder, the master cylinder and pushrod must be disconnected from the clutch pedal. If not disconnected, permanent damage to the master cylinder assembly will occur if the clutch pedal is depressed while the slave cylinder is disconnected." Basically this procedure says: Open the bleeder and let it run.
The other procedure I have states (in short) to:
1. Disconnect the coupling at the transmission with a coupling disconnect tool
3. Remove cap and diaphragm and fill reservoir to the step
a. By hand, apply 10-15 lbs. to clutch pedal.
So you can see why I'd be confused. Right?
Can anyone verify which procedure to use???
Thanks!!!
Old 03-25-2003, 11:27 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Do you have a visible bleeder valve at the transmission? I'm not sure the exact procedure for this, but pump the clutch in and out several times, then hold it on the floor. Have someone else crack open the bleeder valve for maybe a second. Repeat this until the pedal gets firm, making sure to keep the master cylinder full of brake fluid. Gravity bleeding it at first may help get it bled faster too. That's where you open the bleeder valve and just let gravity pull the fluid down the line from the master cylinder. Then bleed it normally to get the remaining air out. Hope this helps, I don't have a lot of experience with these clutches, but I think that might work.
Clutch line popping off slave cylinder templars Ranger & B-Series 3 07-07-2015 09:35 AM
bleeding clutch b_man360 Ranger & B-Series 3 01-19-2013 07:36 PM
Slave Cylinder problems mnmurphy Ranger & B-Series 6 05-19-2011 07:54 AM
Perfection brand slave cylinder issue duckshepherd Ranger & B-Series 2 03-19-2011 03:01 AM
2002 Ranger Clutch Problem novakp2 Ranger & B-Series 2 12-04-2010 04:30 PM
Tags
93, bleed, bleeding, brakes, clutch, ford, ranger, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
