You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 1992 Make: Ford Model: F-350 Price: $7000 Mileage: 10000 Color: white Private or Dealer Listing: Private Listing Location (State): ND Transmission: Automatic Drivetrain: 4WD & AWD Color: White Engine: 351M
Motor is a 351M, bored .030 over, shaved heads, Lunati cam (Adv. Duration 290/300, Lift .536/.562), 4 barrel intake and carb(new), fender well headers, dual points Mallory distributor, 10 qt oil plan, with windage tray. Trans is a C6 auto(a extra stock C6 included) with a shift kit and a 2500 stall converter, with a external filter. Transfer case is a 203/205 doubler with a triple stick shift lever. Rear driveshaft has 1410 ujoints, front has 1330s. The Front axle is a D60 with 5.38 gears riding on a detroit locker that feeds 35 spline axle shafts(inner and outters) Drive flanges instead of lockout hubs and a axle truss. Rear axle is a Ford 10.25 with 5.38s with welded spider gears(a extra axle shaft included) and a thick diamond plate steel diff cover. It has dual two speed electric cooling fans, 100 amp alternator(lifetime warranty), dual batteries, hydraulic assist steering, 44x19.50x15 Pitbull Rocker tires on 32 bolt beadlock wheels, and a 33 gallon gas tank with a electric fuel pump feeding a return style pressure regulator. Its riding on Superflex 4 inch lift coil springs in the front with extended radius arms, rear is stock springs with a shackle flip. Front and rear receiver hitches, front grill guard/push bar. Custom dovetail bed with toolbox. Wheelbase is about 145inches. It is registered/titled as a Class III OHV.
It is a VERY capable off road rig.
__________________
Dave
2003 Excursion Limited, V10, 3.73s, 285/75R16s
100% posting from iPhone
Reason: Price Change
