1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
what are you guys running in your 4r100's?
Old 09-11-2011, 09:06 PM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
I was thinking about using the valvoline extended mileage crap
supposed to be for transmissions with over 75,000 miles
mine has 120k
what are you guys running?
Old 09-12-2011, 03:52 AM
CPaulsen's Avatar
CPaulsen
CPaulsen is offline
I just use Mercon V.
Old 09-12-2011, 04:09 AM
1973Ford2004's Avatar
1973Ford2004
1973Ford2004 is offline
Plain ol' ATF that's what my manual calls for, just changed it in July no problems so far I'm creeping up to the 118k mark
Old 09-12-2011, 06:44 AM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
I just changed to amsoil atf my trans has 155,00 on it. we will see,
Old 09-12-2011, 10:49 AM
jc8825's Avatar
jc8825
jc8825 is offline
Mercon V, 215K.
Old 09-13-2011, 03:00 PM
powerstroker100
well the valvoline says its mercon rated, think I might try it, going to dump the torque converter too, how do I fill the torque converter back up though? dont want to start the truck with it dry
Old 09-13-2011, 03:51 PM
barthel's Avatar
barthel
barthel is offline
Drain the pan and the TC. Once it's all out, put in 6 quarts. Start the truck and cycle through the gears, this will fill up the TC. Shut down, then add 6 more quarts, do the same thing. Once you've cycled it twice then fill to capacity, warm it up (dive it) then top it off if needed.
Old 09-13-2011, 05:55 PM
powerstroker100
thanks for the help
Old 09-13-2011, 06:31 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Here's a great way to change the fluid, preferred method by our resident transmission guru Mark K.
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
powerstroker100
10-23-2011 01:19 PM
rmurphy71
04-03-2011 11:07 AM
Neil64
20
04-25-2008 01:56 PM
clux
05-01-2007 08:38 PM
sjeff35
Aerostar
03-15-2002 04:29 PM
Quick Reply: what are you guys running in your 4r100's?
