OT: Not a good day towing the boat home
Well not a good ending to a pretty good day. Tire started to wobble on the trailer when we were almost home. Ended up coming off when I was pulling into the gas station. Looked in my owners manual and looks like there is a inner and outer bearing. I'm going to check it out more tomorrow but here are some pics of the wheel. I'm just hoping I can find parts and the axle shaft is not damaged. More pics to come. BTW that's the drum still attached to the wheel..lol...
Yeah, It was pretty obvious. I just need to figure out the extent of the problem and don't want to buy parts if my axle is messed up. I've already seen some signs of if but not sure where the bearing rides. My initial scope of it after getting home wasn't good but will check it out more.
I know and thankful, but did have ww damage but I can fix that. We broke down in ABQ, lucky we found a guy that would tow it on his trailer....wasn't pretty and he went 15-20 mph all the way to our house.
I guess I just needed to vent and moral support. Thanks for your support and my other fte bro... I'll post up some more pics tomorrow. I need to tear down the other side to see all the missing parts on the one that let go.......
If its a Dexter axle, its not that difficult to fix, any trailer place will have the parts. prob need a new spindle and hub with bearings already installed. I do these quite often on boat trailers. It looks scarey, but in reality its a pretty simple job.
Glad that you caught it before it passed you on the highway.
Inspect, repack and replace the seals on the other side. Install a new set of bearing buddies and you good.
That's what I ran into with a horse trl, the dam spindle welded to the axel. Like Frank said if the spindle can be replaced it's not a bad job. Good luck with it Grant
We have not done any work on it. Not sure what happened other than it's jacked up now.
Yeah lucky it didn't let go on the highway, not sure what it would of done but I'm sure it wouldn't be good. It's a four winns trailer. Says they manufactured it but not sure the brand of the axle. I attached a pic of the axle spindle. I assume the scaring is where the outer bearing rides. Guess I need a new spindle. Thanks for the advice.
I'll figure it out. Thanks Bud!
I hear you bro and thanks for the concern. I did have some warning and slowed down when I felt the trailer acting wierd. I would hope the same would happen on the highway. After looking into the problem a little more the cotter pin broke off. So I'm thinking there was to much slop on the wheel causing it to break. Good reminder to check stuff out annualy but sometimes hard to keep up with everything. I have three trailers and three vehicles. I'm usually pretty good about my vehicles but sometimes the trailers get ignored a bit.
bkuuz1
09-04-2013 09:22 PM
r___r
05-27-2013 12:20 AM
ronnie pettit
07-13-2010 08:18 AM
restoringmy46
01-15-2007 01:20 PM
