Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 06-06-2011, 10:11 PM
cabledj cabledj is offline
Garage is empty, add now
cabledj is starting off with a positive reputation.
Electric brake plug wire route What route Blue wire take. Not found in rear.
What is the route of the blue wire from the electric brake controller plug to the rear of a 1997 Super Duty (F450)? I found the plug under the dash.
The red wire works from the brake, the black has 12V, the white is ground, the blue wire is hot when the controler is activated.
This at the plug.
I cannot find the blue wire at the rear of the truck. It is not with the tail, turn wires at the rear. I need to find out the routing path to locate it.
I think is has been cut short somewhere. I can follow it from the plug to near the steering column but then it goes into another harness and I cannot follow it.
I am new to the site so bear with me if I do not post or reply correctly.
Thank you in advance.
P.S. Where will I find your reply to this question on the site?
Tags
12v, 2008, 2011, blue, brake, brakeplugs, electric, explorer, f150, f350, finding, flex, ford, plug, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
