Diesel with NO electronics please - Ford Truck Enthusiasts Forums
Old 06-06-2011, 09:02 PM
smrvt smrvt is offline
smrvt is starting off with a positive reputation.
Question Diesel with NO electronics please
I'm looking to buy a 4WD F350 dump, but I want one that does not rely on electronics and computers to run. Does anybody know - What the newest model that doesn't rely on electronics?
Also anything special I should watch out for in that type of vehicle?
SMRVT
Old 06-06-2011, 09:59 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
94.5 was the last year for the IDI diesel (7.3). If it is an uato trans then it has a computer to run the trans but the manuals were totally mechanical. They also offered these trucks with a factory turbo option (these are pre powerstroke).
Old 06-06-2011, 10:02 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
1994 was the last year for the IDI Diesel witch uses no electronics, just 1 single wire for the fuel shut off selonoid to turn the engine off. 2 versions were available that year, non turbo and factory turbo.
Cavitation was a problem with the 7.3, do a search for SCA additives and Cavitation in this forum, you'll find PLENTY of info on that subject.
Nothing else really, very simple and cheap to maintain trucks! Make sure you see the truck COLD (as in not been warmed up before you getting to it) that could mean hard cold starts problems, witch are usually easy and cheap to fix.
Now since you really don't want electronics, you'll have to get a 5 speed standard truck, as the only auto tranny for those years was the E4OD, and relys on nothing but electronics. If you go a lil older, saw late 80's and older, you can get one with the C6 3 speed, 0 electronics on that tranny, and very tough but no OD....
front diff electronic lock? Cthibo366 1999 to 2016 Super Duty 3 04-27-2012 12:26 PM
Disgruntled grizfrmmt22 1987 - 1996 F150 & Larger F-Series Trucks 4 10-29-2011 09:14 PM
Electronic vs. Manual shift 4x4 tpetty 1999 to 2016 Super Duty 7 10-17-2004 04:48 PM
electronic variable response turbo bigpowerstroke 1999 - 2003 7.3L Power Stroke Diesel 4 08-01-2004 06:56 PM
electronic ignition Scott_in_Canada 1967 - 1972 F-100 & Larger F-Series Trucks 7 06-20-2003 11:30 PM
Tags
1994, 73, computer, diesel, electronics, engine, f250, f350, find, ford, fuel, idi, sale, shut, solenoid, truck, trucks, vehicle, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
