Corrosion on Surfaces
I have noticed a good amount of rust forming on the surfaces of the bottom of the engine, drive shaft, rear differential, and other sufaces. It appears to only be on the surface. I'm new to heavy duties, and am not sure how Ford protects their sufaces. Just wanted to make sure this is normal and nothing to be concerned about and that they didn't miss treating these surfaces in the factory.
Unfortunately, that's normal on Super Duties.
Spray some Fluid Film on those surfaces and your truck will be fine: Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
When my truck arrived it had rust on the stuff you wrote about. I sprayed Fluid Film on everything and this is a picture after a winter.
Basically stopped the rust that had formed and prevented anymore...
speakerfritz
1999 to 2016 Super Duty
28
04-22-2015 09:46 AM
