89 F-150 5.0, Still wont start
Well the weather here is finally nice the problem with the system not energizing is fixed bad ground, but the truck still wont start, 1st I have checked the ignition coil with a bulb it flashes when the key is turned and engine turns over, I still need to check for spark at the plugs but a friend was helping awhile back and got shocked so they should be good, I have check for fuel at the releif valve it squirts out when released so should have fuel going to the injectors even if not enough pressure it should at least start, when the key is turned engine turns over like a champ you hear the blomp blomp (bad sound effect) like it wants to start it just dont fire off. then second I have now reaction to the dash the gauges do not move when the key is turned on and off no movement I have power to the dash cause dash lights come on fuse'e are good, dont know what else??? any help would be great I am going to pick up an ignition module that goes to the distriutor see if that helps.
Same can be said for the friend shocking statement. The difference between 5000 volts and 40000 volts feels the same, it hurts like hell. 5KV will not fire off a fuel/air mixture, but 40KV will.
