p0171, p0174, p0401 99 ford E350 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-06-2011, 11:55 AM
flyinghi3 flyinghi3 is offline
flyinghi3 is starting off with a positive reputation.
Hello,
I have a 99 ford E350 with 112K miles, that im trying to chase these trouble codes. i do know that 171, and 174 is lean bank 1 and lean bank 2. i have checked for vacum leaks in/on the hose's, and didnt see anything. also checked the PCV hard line going from the back of the intake to the valve cover, and all looked good. took the air filter off and looked at the MAF sensor. visually it did not look dirty. i have changed out the DPFE sensor, as i found on the internet by changing this this could get rid of 171 and 174 code as well as the 401 code.
i have not taken the EGR valve off yet to see what it looks like inside, but could that be something that would cause these codes.
also the fuel filter has not been changes in a couple of years, the last time it was done was back in 8/04 at 72K miles.
i have reset the code several times, and it seems to come back on around 40 miles later. not sure were too look next.
Mods i did not see a forum for E350's so if im in the wrong place can you move it please.
Thanks,
Old 06-06-2011, 03:55 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
The full-sized van forum is here:1968 - Present Full Size Vans - Ford Truck Enthusiasts Forums
However, if you can be a little more specific about which engine you have, I can direct you to one of the more engine specific forums where you should be able to get a few more responses.
Old 06-06-2011, 05:41 PM
powerstroke,
its a 5.4 triton gasoline motor. this is a 15 ft box truck.
thanks,
Old 06-06-2011, 07:09 PM
Thor80 Thor80 is offline
Thor80 is starting off with a positive reputation.
You may want to look/post in the Modular V8 section found here:
Modular V8 (4.6L, 5.4L) - Ford Truck Enthusiasts Forums
I had a lean bank 1 code on my 99 Expedition ended up being the PCV hoses were rotting away. But it sounds like you've checked that already. Anyway you may have some luck in the V8 forum as this is more of a motor specific issue.
-Torsten
Old 06-06-2011, 07:25 PM
-Torsten
thanks torsten, ill post over there. BTW the PCV hose on this truck is a hard plastic hose.
Old 06-06-2011, 08:12 PM
Zedrive's Avatar
Zedrive Zedrive is offline
Zedrive is gaining momentum as a positive member of FTE.
Pull the pcv elbow off at the manifold end and, really check the rubber elbow closely.
Mine split on the uunder side.
Old 06-06-2011, 08:25 PM
-Torsten
Thanks Torsten. I was about to post the same link to the Modular forum and lost internet service.
Old 06-07-2011, 12:55 AM
Quote:
If its like my Expy though there is some rubber, the elbows and a small length or two. My PCV had a split right at the valve cover with short lengths of rubber hose attatching to the hard plastic.
Quote:
powerstroke72
<table width="100%" border="0" cellpadding="6" cellspacing="0"><tbody><tr><td style="border: 1px inset;" class="alt2">
</td></tr></tbody></table>
No problem. Luck of the draw eh?
-Torsten
Misfire! Mrdbraun Modular V10 (6.8l) 9 02-08-2017 10:19 PM
Misfire! Mrdbraun 1968-2013 Full Size Vans 3 05-17-2016 12:19 PM
96 F250 7.5L 460 PO171 ,174 CODES Mr f250 1987 - 1996 F150 & Larger F-Series Trucks 1 02-22-2016 12:25 AM
P0171/P0174 on 1998 Expedition 5.4 dhenthorn 1997-2006 Expedition & Navigator 3 06-28-2011 07:07 PM
p0171, p0174, p0401 ford E350 trouble flyinghi3 Modular V8 (4.6L, 5.4L) 0 06-06-2011 07:34 PM
Tags
1997, 54l, 96, 99, code, duty, e150, e350, econoline, f350, ford, p0171, p0174, p0401, po174, super, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
