NEWB NEED HELP PLEASE - Ford Truck Enthusiasts Forums
Old 06-06-2011, 11:39 AM
04_FX4 04_FX4 is offline
04_FX4 is starting off with a positive reputation.
JUST BOUGHT A 04 FX4 5.4 3V. HAVE A FEW PROBLEMS TO WORK OUT OF IT BUT GOT IT FOR A DAMN GOOD DEAL. ANYWAYS DOES ANYONE HAVE A LINK OR COULD EMAIL ME A DETAILED DESCRIPTION OR PIC OF THE VACUUM LINE FOR THE 4X4 SYSTEM SEARCHED THE THREADS DIDNT REALY FIND WHAT I WAS LOOKING FOR OR DOES ANYONE LIVE CLOSE THAT HAS A TRUCK I COULD POSSIBLY LOOK AT FOR REFERENCE
THANKS
Old 06-06-2011, 07:46 PM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
Do a search on here for a thread called, "Everything You Wanted To Know About The IWE System". I think there is a schematic of the vacuume, lines, but if not he explained where all the liines go.
Old 06-06-2011, 08:50 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
Old 06-06-2011, 09:37 PM
i did read the main post this thread pervious to posting mine.Very good write up on that one xjcamaro89.Maybe i need to reread it because didnt quite find what i was looking for.Trying to find where the bottom line on the iwe goes one end comes from the air box behind the battery,the other end is t'ed into the iwe the other end is cut shortly past the t.So trying to find where this mysterious other end goes.there is no line on this t branch that goes to the port behind the intake manifold. my first guess would be there.I'll reread but any help is appriciated thanks.
Old 06-07-2011, 07:23 AM
xjcamaro89's Avatar
Maybe take some pics and post them so we can see what your seeing.
Old 06-07-2011, 09:08 AM
C:\Documents and Settings\suser2\My Documents\My Pictures\IMAG0111.jpg
C:\Documents and Settings\suser2\My Documents\My Pictures\IMAG0112.jpg
C:\Documents and Settings\suser2\My Documents\My Pictures\IMAG0113.jpg
Old 06-07-2011, 09:11 AM
xjcamaro89's Avatar
You will probably have to upload them to photobucket or your photo album in your user control panel and then use the insert image function when responding to the thread.
Old 06-07-2011, 09:22 AM
http://www.ford-trucks.com/forums/picture.php?albumid=18257&pictureid=71900
WHAT IM LOOKING AT IS THE BOTTOM LINE ON THE IWE
Old 06-07-2011, 09:40 AM
xjcamaro89's Avatar
Im not seeing any cut lines. You should have one line coming off the intake somewhere, depending on your motor. That line should go to the top of the IWE solenoid. From the bottom of the IWE solenoid it T's off and one line goes to the box between the battery and the fender, the other line starts down towards the wheel well. At that point i beleive it T's again and each line goes to each front wheel to the IWE actuator which is mounted on the backside of the spindle. From each IWE actuator is a vent tube (which you might be talking about) it comes back up through the wheel well into the engine bay and is just left open (maybe looks like it is cut).
Old 06-07-2011, 09:46 AM
OK THATS THE ONE I WAS TALKING ABOUT THE LINE AT THE BOTTOM WAS T'ED INTO THE SOLENOID AND THE BOX THEN WHERE IT IS SUPPOSE TO GO TO THE IWE ACTUATOR IT WAS CUT ABOUT TWO INCHES AFTER THE T TO THE SOLENOID NOT SEEING ANY T'S TO THE IWE ACTUATOR BUT GONNA DO SOME FURTHER INVESTIGATING.
Old 06-07-2011, 10:08 AM
xjcamaro89's Avatar
Ya the one bottom line should go down into the wheel well and T off at some point to go to the other wheel. If that line is severed then your wheels are locked in all the time. But not in 4WD.
What you could do is is either find the lines that go to each wheel and just use a chunk of vacuum line to patch the section missing, or from that cut line, use some vacuum line and run your own lines where ever you want down to each wheel and connect it to the bigger of the two vacuum ports on the IWE actuator.
But since it looks like someone hacked the vacuum system, you might want to get a good vacuum guage from the parts store so if you do the repairs you can check all the lines once finished to make sure you dont have any leaks. You will probably want to check the IWE actuators to make sure they are holding vacuum and releasing like the should. If they are not, then you will need new ones, cause at that point it wont matter what you do with the vacuum lines, if the IWEs dont hold vacuum or release then your wheels will stay locked.
Old 06-07-2011, 10:32 AM
SO FROM THE VACUUM BOX THE LINE SHOULD T INTO THE SOLENOID THEN GO TO THE IWE ACTUATORS CORRECT.
Old 06-07-2011, 10:52 AM
xjcamaro89's Avatar
Yes, and once that line gets down into the wheel well somewhere it should T off again so one will go to each wheel.
leveling kit question backtrailboy2332 2004 - 2008 F150 1 10-04-2010 07:02 PM
Skid Plate 714x4 1999 to 2016 Super Duty 3 12-19-2008 05:27 PM
Prerunner Bumpers moto92 2004 - 2008 F150 1 02-20-2007 12:00 PM
Need Homelink Mirror for 04 FX4 RyRy04FX4 2004 - 2008 F150 3 10-09-2006 09:43 PM
AUDIOPHILE Upgrade~ Worth It? RED04FX4 2004 - 2008 F150 9 04-15-2004 06:48 PM
Tags
1997, 2005, 4x4, actuator, bronco, expeditioniwe, f150, ford, iwe, parts2003, problems, replacement, solenoid, system, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
