P0113 - Intake Air Temp High... replace IAT? - Ford Truck Enthusiasts Forums
Old 06-05-2011, 11:49 PM
43Duc's Avatar
43Duc 43Duc is offline
43Duc is starting off with a positive reputation.
Hey guys, I'm getting the above code about once a month or so in my 2006 5.4. Is this something that I need to replace, or can I just pull the MAF and clean it? If replacement, is it possible to only replace the IAT, or do I have to replace the entire MAF?
For what it's worth, I'm running a KN filter (not cold air intake) and had run it for a year before the codes started popping up. I don't over-oil the filter, so I don't think it's an oil issue. I've got about 50k on the clock.
Am interested in hearing what you all think.
Also, I don't have a tech manual for my truck. Which of these is the MAF sensor:
-CB
Old 06-06-2011, 07:00 PM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
Clean the MAF and the sensor, then loose the K&N. Just my opinion, but I've read on here and heard that any filter that gets oiled caused problems eventualy.
Old 06-06-2011, 07:53 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
you should just clean the maf and throttle body . i clean them every oil change and dont have a problem running the k&n. it does get dirty between cleanings though, so im sure that has something to do with your problems.
Old 06-12-2011, 12:08 AM
43Duc's Avatar
I took the module I labeled "A" in the picture above out to see about cleaning it. As far as I know that's the MAF and the IAT is integrated in that device. However, once I had it out I couldn't really see how to clean it. Any ideas? Did I take out the wrong thing?
Old 06-14-2011, 05:00 PM
COUNTRY0017 COUNTRY0017 is offline
COUNTRY0017 is starting off with a positive reputation.
HAD THIS HAPPEN ON MY WIFE'S TRUCK I JUST TOOK IT OUT AN SPRAYED CARB CLEANER ON IT AN USED A DENTAL PICK TO CLEAN IT BUT BE CAREFUL DON'T BE TO ROUGH WITH IT. JUST AN FYI I PUT A K@N FILTER IN HER TRUCK A MONTH BEFORE THIS HAPPENED.
Old 06-14-2011, 09:45 PM
Jr.Ranger-04 Jr.Ranger-04 is offline
Jr.Ranger-04 is starting off with a positive reputation.
Loose the K&N it is of no value....
Gabe's 86 flaireside rebuild 86Stepside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 09-11-2016 12:18 PM
4" BDS, 18x9 Monster 778's installed (PICS) mankypro Excursion - King of SUVs 45 12-28-2013 09:11 PM
Yay! 4" BDS installed - wheels and tires this afternoon! (PICS) mankypro 1999 - 2003 7.3L Power Stroke Diesel 28 12-28-2013 09:05 PM
Wire identification questions Murf77 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-12-2011 09:34 AM
Tags
06, 2000, 2004, 40, air, f150, f250, ford, high, iat, intake, location, normal, p0113, po113, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
