HELP! Whining Noise from 06 F-250 - Ford Truck Enthusiasts Forums
Old 11-21-2014, 11:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all:
Print Wikipost
Old 06-05-2011, 11:23 PM
tlfksu's Avatar
tlfksu tlfksu is offline
tlfksu is starting off with a positive reputation.
Hey all. I just recently had my truck in (06 F-250) to have a few leaks fixed and a new caliper put on after it seized up and fried my rotor, seal, etc... I had two leaks, one rear main and one oil pump. Drove the truck home and 5 min later I had a baseball sized slick under my truck of fresh oil. This really ticked me off as the leaks before were a drop or two per month. I also noticed an odd whine coming from my truck. I know it's not my imagination because it was annoying the heck out of my fiance as well and she is not very observant to say the least. The noise is a very audible whine that occurs at low to mid range rpms (up to about 1500-1700). The pitch of the whine increases with the rpms and eventually goes away at higher values. It's much more noticeable under slow acceleration and if you accelerate to 1500 rpms and let off the gas, it is pretty loud for a moment and then dies off with the engine speed. I'm very **** about my truck and I'm 100% positive it wasn't there before. I wouldn't worry about it but it's loud enough that it's starting to annoy me. I took the truck back so they could fix the leaks (which they seem to have done right this time) and they told me this sound is perfectly normal on diesels. I'm not buying this as my family had owned diesels for years and I've never heard this sound. If anyone has ever experienced this problem or knows of a fix, PLEASE let me know as I'm very worried about it. If it's nothing to worry about, PLEASE put me in my place. Thanks so much for your help and sorry for the long-winded message.
Old 06-05-2011, 11:27 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Could it be low on power steering fluid? Have you checked its level?
Old 06-05-2011, 11:39 PM
tlfksu's Avatar
Quote:
I checked it a week or two ago and it was good. I'll check it again tomorrow though to make sure. If that was the case, would it whine all the time? Or just when you turn? Because my truck is doing at under acceleration at all times. Thanks for your help.
Old 06-07-2011, 09:44 PM
tlfksu's Avatar
Finally got time to post and my steering fluid is full. Thanks for the advice though. Never hurts to check. Does anyone have any other ideas? This noise really has me worried and it's not even fun to drive it anymore because I'm waiting for it to blow up (slight exaggeration). Again, any help or suggestions are GREATLY appreciated. Thanks.
Old 06-07-2011, 10:12 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Check to see if your intake from the air cleaner to turbo is loose.also check from turbo to aftercooler.chances are all that stuff was taken off if they re-sealed the hpop.
Old 06-07-2011, 10:16 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Does it make the noise when in park, or just going down the road?
Old 06-07-2011, 10:49 PM
tlfksu's Avatar
Quote:
There was one instance where it made some noise while in park. But it wasn't the EXACT same sound. But it ALWAYS does it while I'm driving....
Old 06-07-2011, 10:51 PM
tlfksu's Avatar
Quote:
I'll check that tomorrow after work when it's light out. Thanks.
Old 09-25-2011, 09:35 PM
johnthoms johnthoms is offline
johnthoms is starting off with a positive reputation.
I am having exact noise has me worried also I just can't pin point the sound ,sounds like slight ps pump or tranny checked both fluids both perfect this has me really stumped any updates yet I really would love some ideas
Old 09-25-2011, 10:06 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
If the noise is as bad as you describe, you have to be able to post up a video of the noise you hear, before I would be willing to speculate what it could be.
A little word of advice. When returning to the dealer, never say the words "EVER SINCE YOU......" to the mechanic when describing the problem you want addressed. I can tell you that THAT is one of my biggest pet peeves of customers, is when hearing those words at the beginning of their description of their symptom. Although, I very seldomly hear those words from customers, I could tell you stories upon stories of the top ten stupidest "Ever since you ...." accusations that other fellow techs have told me, for a good laugh. But that's a whole 'nother story.
Back to the topic at hand, is the sound a WHINE, or a DROAN? Does it occur while in PARK or NEUTRAL, or while stopped with your foot on the brake in DRIVE or REVERSE? You say it diminishes above about 1700 RPMs. Does it diminish when you rev it up above that speed in PARK as well, or only while driving?
Old 09-25-2011, 10:14 PM
lenzhotrod lenzhotrod is offline
lenzhotrod is starting off with a positive reputation.
I almost wonder if the torque converter wasn't installed right when they did the rear main seal.
Old 07-23-2012, 07:52 AM
Enomra's Avatar
Enomra Enomra is offline
Enomra has a good reputation on FTE.Enomra has a good reputation on FTE.
Did you ever get this fixed? If so what was it?
Old 08-29-2012, 10:43 PM
stokedguy stokedguy is offline
stokedguy is starting off with a positive reputation.
I have an 04 350 with 100,xxx on it lifted chipped with 4"from the turbo back. The normal whistle from the turbo at any engine speed has changed to more of a whooping or whushing sound all fluids are good need help
Old 08-09-2015, 09:28 PM
jpalladino820 jpalladino820 is offline
jpalladino820 is starting off with a positive reputation.
I have a 2005 F350 Super Duty Crew Cab Long Bed thats making a whining sound. You hea r it more at slow speeds, accelerating and decelerating. At approx. 45mph you don't hear it anymore but I wonder if the speed drowns out the sound. Also when I apply the brakes the sound disappears. Could it be a warped rotor? All my fluids are fine. Truck has 43,000 miles. Noise started about 1800 miles ago on a trip from Florida to Minnesota. I can't exactly pinpoint where the noise is coming from.
Engine whine, Little power, Engine miss under WOT 08longbox6.4 6.4L Power Stroke Diesel 2 09-29-2016 08:18 PM
NP435 advice needed moroza 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-20-2016 05:14 PM
whining noise in rear when pushing throttle? fx4_canada_guy 2004 - 2008 F150 20 01-15-2016 10:24 PM
Transmission Whine 78F150Lariat Clutch, Transmission, Differential, Axle & Transfer Case 3 01-24-2007 03:37 PM
Whining noise on deceleration BigRed FX4 Clutch, Transmission, Differential, Axle & Transfer Case 2 01-30-2005 06:50 PM
Tags
06, 2003, 60, 60l, accelerating, diesel, f250, ford, gas, letting, noise, sound, whining, whinning, woning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
