Ford truck parts 61-98 roof skins etc
on
Category: Accessories
Price: $5
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude, Fit, S2000, CL, TL & Vigor
Post your want list!
Here's my list for the moment.
Interior pieces.
Passenger side dash pad.
The dash piece that's below the steering column, that goes between the ash tray and the drivers door.
Drivers side power window, mirror, and door lock switch cluster plate. The black piece the switches mount to.
Rubber E-brake pad that goes over the pedal.
Other parts.
Front coil springs out of a Lightning.
license plate light bulb housing. I'm not sure what the name is. They mount to the bumper on each side of the license plate.
I need a drivers side upper bed corner above the tail light. I'll send you a pic for reference.
Thanks in advance
Interior pieces.
Other parts.
Thanks in advance
Hey, if you find any good wheel arch chrome and dent moulding for a shortbed dentside, I'd be interested, thanks. And if by chance there is a good steering wheel (i highly doubt they exist) for a '73-'77, that too, also, good black inside door panels, mine are the somewhat fancy ones with pleated "pleather" but any good black ones would do.
I figured that, the plastic hasnt survived to well anywhere after 35 years, let alone the furnace of Las Vegas . Let me know what you find, thanks!
I really could use the drivers side front interior door panel for a 1997 F-350 crew cab, tan and electric windows & door locks. This requires the hole for the big switch piece that has 4+ switches. If you find one I may come & get it (live in AZ could use a vacation) or we'll figure something out. Thanks, Kenny
I'd be interested in the ignition bezel and mounting ring for 65 F-100
also the connector the longer the leads the better.
I'd take the whole ingnition if it had the keys
thanx
thanx
