460 oil pan capacity - Ford Truck Enthusiasts Forums
Old 06-05-2011, 04:17 PM
jniolon's Avatar
jniolon jniolon is online now
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
something that just occurred to me. Swapped oil pans from front to rear sump for MII. I'm not sure if this is a 5 or 6 qt pan ?????
anyone know for sure ..
I bought this pan from Bishop's out in Texas... the ticket says 460 oilpan # 535
can't find a reference to a #535 pan so I'm assuming it's Bishop's internal number
here's a pic of the pan
thanks
John
Old 06-05-2011, 04:28 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I thought because of the double hump, there was 1 more quart.. so 6.
plus oil filter, 7 on filter change
my mid sump is flat on the front. and is full at 6, including filter
Sam
oil pan gasket loveless41908 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 07-10-2014 09:43 PM
oil pan removal clearance 460 1990 F-250 chincycoot 1987 - 1996 F150 & Larger F-Series Trucks 6 08-30-2013 07:47 AM
460 oil pan and pickup tube recommendation CaptainIPSC 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-03-2009 09:35 AM
79 460 oil pan leak ford-man 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-14-2007 10:23 PM
Where to find code 535 on the vehicle hdbngr8 1997 - 2003 F150 4 02-08-2006 12:59 PM
Tags
1973, 1977, 1978, 1994, 460, capacities, capacity, e350, engine, f150, ford, mid, oil, pan, sump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
