Truck Parts
Truck Parts
Does anyone know of a parts outlet for the metal bed floor strips for a truck ? I have called Dennis Carpenter,Macs,C&G,Obsolete ford,vintage ford,carolina-classic and FR truck parts. What I need is the metal strips that hold down the wood floor. -BUT- In 12 ft lengths,not 6 or 8. Its for a 11/2 T flatbed. Also if possible the hardware for the sides of a stake bed. I need them for a 1932 flatbed,but im sure all the flat beds strips were the same for years,or close enough so they can be used. Also I word rather them be a plain steel then chrome. I guess if nothing else I will have to get 2 eight foot sets and weld them together. Just thought one of you guys might know of a outlet. THANKS !
Thanks guys for the quick reply ! I am not new to building. But I am new to "FTE" , Most that have built have been with late model running gear. This is my first at almost orginal. The only change was from a 4 cylinder to a flathead V8. About all I have left to do is maybe the bed floor. Its running & driving. I have had thoughts of converting it from 6 volt pos ground. To 12 volt neg ground. Having the generator converted or getting a generator from a 55-56 ford. If you get a chance I just posted a couple pictures in my gallery,check it out. Comments,advice and input are get too ! Thanks
