Why would one cylinder on my 2000 V-10 fill up with raw fuel when injector is unplugged from harness? New injector and still fills with fuel!
I can't understand why only one cylinder.
All help and suggestions are greatly appreciated.
Can anyone tell me why my 2000 V-10 would fill one cylinder with raw fuel,even with injector unplugged from harness? New injector still same problem. I can't understand why just one cylinder.
All help and or suggestions are greatly appreciated.
i pulled all plugs and started to run compression test and cylinder #9 was fouled and,would just shoot a stream of gas out of plug socket up to firewall.
i then disconnected all injectors on that side and spun motor over to help clear out gas.
compression was 130# on all cylinders of that side of motor,new injector and spun motor over and gas again shot from same cylinder, and I had not even plugged in a single injector yet.
it wasn't locked up ,but it did try too while cranking,just let it sit a few seconds and it turned over,it practicly had raw gas coming out of exhaust, 1/2 ring around outside of tailpipe wet with fuel.
Reason: complete answer
Sounds like it could just be a leaky injector (even new parts can fail). It would explain the pressure drop and why it is flooding one cylinder, even when the injector is unplugged. You could swap the injector from the cylinder that is flooding with another and see what happens.
I will try the injector swap and see how it goes,but that is what i thought when i first found it and, therefore got the new injector.but again i will relocate it to an easier cylinder to access,lol
thanks
only other thing i can think of to check is the fuel pressure regulator, possibly leaking fuel into the vacuum line and into cyl # 9 that way or you didn't get all the fuel out from the first injector swap
